05-18-2024, 12:15 AM | #1 |
How screwed am I (tt250)
Hey everyone. I was doing an oil change on my 2019 tt250 and while unscrewing the drain plug part of the thread just fell out. It’s leaking a ton of oil now even with the plug in as far as I can turn it. I know how to weld and could try to seal it back up, but it would be a decent amount of work to get it to the shop I weld at. Anyone have any ideas?
This image is with the piece that fell out shoved back in place (it still leaks oil) |
05-18-2024, 01:19 AM | #2 |
If you can get it clean enough - aka oil free - your best bet would either be to weld it on or epoxy it back in place. Then just chase the threads out.
You could use a die to cut an aluminum thread insert and then weld the hole shut and do your oil changes from the filter screen side as a secondary option. A lot of the newer CG and CB engines don't even come with a lower drain plug. Otherwise, you need a new case half.
05-18-2024, 07:28 AM | #3 |
Or maybe just find the next larger size drain plug and tap to that thread pitch. Good luck.
05-18-2024, 08:43 AM | #4 |
You can't tap into metal that isn't there. Look closely at the pictures and you will see that a chunk of the case containing a not insignificant percentage of threads that the sump plug goes into.
05-18-2024, 09:03 AM | #5 |
What about something like PIG high temp epoxy putty? I've heard some good stories about it from people far more mechanical than I.
2022 Hawk DLX EFI * 17T Front / 47T Rear / 428 x-ring chain * Kenda K-760 front + rear * Banjo brake light switch * LED headlight + front turn signals * Custom cutting board skid plate * Debadged (I don't like to brag about the superior strength!) * Top speed, GPS verified, as equipped: 68 mph (so far) |
05-18-2024, 09:23 AM | #6 |
You may get away with epoxy putty or JB Weld.
Surfaces will need to be immaculately clean and you'll need to be very very careful when torquing the drain plug back in after it's set. I'd almost be leaning towards epoxying the missing piece back in, epoxying the drain bolt in place, and doing your oil changes through the filter screen side plug. Welding cast aluminum can be a major pain due to unknown alloy, outgassing and oil contamination.
05-18-2024, 10:27 AM | #7 |
Here is a completely different idea.
A replacement engine costs under $500. You may even choose to upgrade to a 249cc engine, which might cost a bit more. But the amount of work involved and chances of failure really beg the question, "Is it worth the effort?" The only way to fix this problem with certainly is to break the crankcase in half and replace the broken side. But once you've done that, you may need to replace the seals on the ends of the shafts in addition to the gaskets. What would the parts total be? Can you find them? And it is a whole lot of labor. Do you have bench space in a shop to do this work? Once it is all back together, it is a used Chinese engine that has been broken down and rebuilt. Sure, it can be done, but swapping in a fresh engine is much less work. Just a thought. The quick fix (JB Weld or welding) could work. Just thinking that if it fails, what next?
No matter where you go, there you are |
05-18-2024, 11:56 AM | #8 |
You effed up.
I would suggest to get another plug that has a bigger thread diameter, but it looks like the case is cracked. If you're lucky, JB weld can fix that somewhat, as the crank case and oil aren't pressurized, but no guarantees. It needs welding. Alternatively, I've never tried, but, drain the oil overnight; wipe all excess, get some high tin solder, and a propane torch, and hope for the best that solder will work. Solder won't melt with the temperatures on that part of the engine. |
05-18-2024, 12:04 PM | #9 |
Looks like it may have been smacked at one time. You do any real off-roading?
I'd clean it up good, put a haze of anti-seize on the exposed threads and back of the bolt head and then fill a patch of JB Weld over it. Let it set for a couple days and fill it with oil and keep your fingers crossed. We just had a guy on the RE forum fill a dime size hole in his Himalayan case and it worked great.
05-18-2024, 01:32 PM | #11 | |
05-18-2024, 03:21 PM | #12 | |
05-18-2024, 09:53 PM | #13 |
The "filter" is only there to protect the oil pump from large shavings and chunks of metal. Think of it more like a kitchen strainer than an oil filter. The actual oil filtration doesn't use a filter at all, but is a centrifuge driven off of he crank sitting right next to the clutch. It spins the oil to separate the heavier metal particles out. All that is left after that is the very fine stuff that is so small it doesn't really harm anything.
Also, keep in mind that the CG engine design in particular is intended to be a bit "loose" on the tolerances so it can survive third world abuse (dusty conditions, infrequent oil changes using sub-par oil, etc). Even an "abusive" owner by Western Standards is going to give it far more care than it was designed to tolerate.
