08-04-2011, 10:29 PM | #1 |
Loncin CB250cc air cool engine info and help ??
hey guy i may have found a deal on Loncin CB250cc air cool engine, but it need to be rebuild because the guy who had the dirt bike fell broke the side cover.
do you know where i can find the service manual for this motor ??? or what Honda can you compare too ??? do you think there is any Honda camshaft fit this motor for more performance???
2008 gio beast 200cc mod list YTX14-BS battery mod,gy6 carb 250cc,custom intake,125cc cf dirtbike muffler,MPR filter/intake,performance cdi,ngk iridium xi dpr8eix-9,performance coil pack and wire, pro taper handle bar, Gio air shocks, yam swing arm bus |
08-04-2011, 11:20 PM | #2 |
You want to rebuild it because the side cover broke?
http://www.duncandesignsstudio.com/justinsoddprojects/ |
08-05-2011, 08:59 AM | #3 |
ya because to change the side cover i must disassemble the hole motor, so i will take the time to put new gaskets and rings mabe even a new piston with higher compression and cam shaft. i was also going to port and polish the head for more flow.
08-06-2011, 10:41 PM | #4 |
plz guys i need info asap
:oops: :oops: :oops: :oops: :oops:
08-06-2011, 10:50 PM | #5 |
I'm sorry Anthony, I don't understand why you have to split the cases to replace a side cover... The covers can be unbolted without touching the main case. Do you have a pic of the damage or something?
08-06-2011, 11:06 PM | #6 |
here is the link http://montreal.kijiji.ca/c-cars-veh...AdIdZ301134578
08-06-2011, 11:17 PM | #7 |
Ahhh! I got it now! You were wanting to rebuild it because the previous owner took it all apart already. I can't read french so I have no clue what the ad says other than he want's $175 for it. Personally, I would steer clear of a basket case engine. Sorry this doesn't help you much but I was just trying to figure out why you would want to rebuild an engine just because of a broken side cover. How much does GIO charge for a complete new 250 cc engine? (Though I hate dealing with them, they're pretty much the only game in town in Canada)
08-06-2011, 11:26 PM | #8 |
a brad new from gio is 599.96$$ plus $40.00 for shipping here is the link http://www.giobikes.com/Engines-Comp...r-2010-models/
so if i get that moto for 100$$ i am winner
08-06-2011, 11:34 PM | #9 | |
08-06-2011, 11:36 PM | #10 |
let hope some can help me asap befor he sell the motor
08-07-2011, 12:43 PM | #11 |
I had a look at the images, and I had Son of Weldangrind translate the Kijiji ad for me. The engine doesn't look like a typical Honda clone to me, but it is an OHC engine.
Does your Beast engine still run? If so, I would just get a big bore kit for it to create 230cc, which is likely what the Kijiji engine is. You would not even need to split your engine case.
08-07-2011, 05:27 PM | #12 | |
yess my 200cc beast motor runs but i hate that is is only a 4 speed and that 250cc motor is is a 5 speed
08-09-2011, 07:32 PM | #13 |
bump for help
08-10-2011, 10:28 AM | #14 |
Do you have a pic of the same kind of engine, but fully assembled? If it's a Honda clone with OHC, then Honda XR200R parts and info will be good.
08-10-2011, 01:01 PM | #15 | |
http://www.giobikes.com/Dirt-Bikes-i...ike-21-18-PRO/ Quote:
and also if u read here http://www.chinariders.net/modules.p...wtopic&t=12213 parts from a crf230 can fit in the motor ???
