Old 02-05-2011, 02:21 PM   #1
kperdave   kperdave is offline
110 Hummer not starting after sitting for a couple of months
been here a few times and you have all helped me out quite a bit. My son's 110 hummer has been sitting for a couple of months. It was running fine until we went to start it. it turns over no problem. It just seem like it is not getting gas, or something to that nature. I changed the plug, checked for spark, (seems like there is spark).l However still not sure what the problem could be. Any suggestions???
Old 02-05-2011, 03:18 PM   #2
ejcycles   ejcycles is offline
ejcycles's Avatar
Hi kperdave
Not sure where you are from... but if it sat with old gasoline in the tank & carburetor, the gasoline went Stale & Varnished the carburetor. I always tell people if your gonna let them sit more than 2-3 weeks or longer without use or very little use the fuel will go Stale, it {fuel] needs to be drained out of the tank & carburetor.
You'll need to disassemble the carburetor & clean it, every little part even areas you can't see. If your not sure how to do this find a Really Qualified Person to do it. I have seen many say they can but still don't get them clean.
Thanks, Bruce @ Endless Journey Cycles
"Phone Calls Only" ~330-274-0098~
Hours: Tue.-Fri. 10:00-6:00 Sat. 10:00-4:00 EST.
Dealer for: Lifan, Crossrunner ATVs.
http://www.endlessjourneycycles.net
