This wire is normal?
When i opened the box of my new Rebel T3, i saw a piece of wire that is cut.
That's normal. :roll: Where this wire is supposed to be connected? ![]() |
That's the clutch lever, right?, if so it's possible that the brake and clutch levers are the same assemblies and the brake lever will have a switch to control the brake light, not needed on the clutch.
#3 | |
Think of it as a built in spare for WHEN the other one fails. :roll:
Happy to serve. |
Finally, it's not like the other side.
The controls that are used on these machines were originally for street bikes and so on. The switch on the clutch lever was likely a safety switch in the original application, but it was not used on your atv. If your atv starts and runs without it, forget it.
