WTB: Rear Rim For Jetmoto
so i got me-self a slight problem...my rear rim is SHREDDING my tubes! 8O i was curious if anyone had a spare rim that they are willing to sell me.
How is the rim causing the problem? Is the rubber band compromised? I don't even use a rubber band, I wrap the rim a couple of times with duct tape to protect the tubes from the spokes.
Maybe you have a spoke that's poing up a bit high; a Dremel will make short work of that.
Also if it is your rim for some reason do you want a whole wheel or just a rim? Would need to know disc or drum too.
Allen
i have the rubber band around it and the old tube around it except it keeps getting shredded :roll: i dont need the disk or sprocket...ive checked for spokes but none of them are poking through
Ok. So you have a rear disc model.
Have you check the rim surface for any sharp sections. Also check the inside of your tire. Allen
