Old 01-21-2010, 04:57 PM   #1
ELECTRIC CHOKE ON GY6 CARB
Does anyone know if you can set the choke on the electric choke ? I would like it to rev the motor up when cold and then kick off when it warms up.... does it work like the ones on a car engine??? other wise I have to keep my foot on the throttle until it does warm up.... better than a cable still .......... gy6 carb.. like ANTHONYS
Old 01-21-2010, 05:27 PM   #2
Reveeen   Reveeen is offline
There is no "setting", it either works, or it doesn't.
You are looking for something with a fast idle cam hooked to the choke. To be truthful I have not seen a motorcycle type carb with this function, fuel injection, yes, but not a motorcycle carb.
It is wintertime, I *think* you could safely block off the carb cooling duct, on the top of your fan housing, remembering to open it up next summer (or the fuel will boil in the float bowl).
Old 01-21-2010, 06:49 PM   #3
CARB COOLING DUCT
this cooling duct.. is it a hose?? on the carb?? I had thought the electric choke would work like a regular choke.. but I guess you just do not have the cable problem.. thanks for the help.
Old 01-21-2010, 10:43 PM   #4
anthonyfa18   anthonyfa18 is offline
Most of the GY6 scooter engines seem to come equipped with the Keihin style CV carburetor with automatic choke. In theory, this is a nice feature - the choke turns on by itself when needed and then shuts itself off
it work with resistance so u just need to add power and a ground and you good to go.
Old 01-22-2010, 02:04 AM   #5
Re: CARB COOLING DUCT
Originally Posted by FLASHLIGHTBOY
this cooling duct.. is it a hose?? on the carb??.
On the top of your fan housing (the plastic bit on the right side that covers the engine cooling fan you can see through the plastic screen) there is a molded plastic tube (about 1 1/4 in diameter) that does a right angle turn, and directs cooling air at the carb. Try a piece of duct tape over the end.
As I said there really isn't any "fast idle" function, try increasing the idle speed (with the idle stop screw) in the colder weather. The clutch really doesn't "come in" until you hit 1000rpm, so bumping the idle speed a bit won't hurt (setting the idle about 800rpm hot should give you 500-600rpm cold).
A "forced air" cooled engine will not behave the same as an "air cooled" engine in the cold, the warm up time is a lot longer, if cold enough it will never "warm up".
My wife once drove a Ford Escort 40 miles home with a burst rad hose @ -45F, it didn't overheat, mighty cold driving with no heater, but it didn't hurt the engine.
Old 01-22-2010, 02:13 AM   #6
TurboT   TurboT is offline
What about the water pump? 8O
Old 01-22-2010, 07:22 AM   #7
waynev   waynev is offline
I think Flashlightboy better fill us in, my guess is this carb has been mounted to a 200cc beast not a GY6 engine, right ? If it's on the beast then that cooling tube is non existant.
Old 01-22-2010, 08:13 AM   #8
Sounds to me like we are "talking" buggy of some sort, unless a Beast has a foot throttle?
Old 01-22-2010, 10:44 AM   #9
Good point, he asked for some logo's so i know he has a few beasts and also referred to anthonys GY6 carb, but yes, foot on the throttle does sound like a buggy.
Old 01-22-2010, 10:13 PM   #10
waynec   waynec is offline
Antbody know what the 500cc Gio Rockliner went for jan 18th?? I see on the site tjhere was a one time , no reserve auction for one? I will be in the market at some point. I have a lane to plow/blow in my future.....thx....waynec
Old 01-22-2010, 10:19 PM   #11
I do believe it was in the 4300 range. There has been a few of them up lately for no reserve, usually 1 per week.
Old 01-23-2010, 12:26 AM   #12
They look very nice. Wish I had the coin, but alas, I don't.
Strange spot for that question in the middle of this thread though!
Old 01-23-2010, 08:29 AM   #13
Thanks..........that puts it just a little more expensive than the Baja from Canadian Tire and seems a whole lot more machine.
Yes i am a heinous offtopicer. :twisted: Sorry 'bout that. The question didn't seem worthy of its own thread though..........waynec
Old 01-23-2010, 07:23 PM   #14
ELECTRIC CHOKE
Hello , as some of the help have said.. I have this on a 150 cc ZSTAR dune buggy.. same as a KINROAD.. and I guess I will just turn the idle up abit.. it sounds better when it warms up and it idles nice and low.. quiet .. it is too bad that it does not work on a fast idle.. I have many atvs.. as I also sell them.... ZSTAR DEALER... and GIO atvs.. But I have a 400 jianshe.. and a couple of the 200 cc GIO'S and a new 800 cc 3 cylinder KINROAD.. dune buggy .. Spring project to ride.. I may try to hook a little switch and a throttle fast idle to over come the wait time to warm up the carb.. we use a hair dryer for easier starting in the -30 C weather on the 150 cc dune buggy.. alot of nice ideas on the site.. everyone keep up the mods..
Old 01-23-2010, 08:53 PM   #15
This is really not a good idea, while an electric hair drier is not an "open flame", it is the next best thing.
When I was but a wee lad my daddy used to use a 100W light bulb on an extension cord under the hood of his car in the winter. This way the first couple of air gulps the engine got on a cold winter morning were pre-heated. Same thing would work on your buggy, be about 100X safer, and maybe you could rig up an old blanket (carefully distant from the hot bulb) to keep the heat in.
