Gio 110cc ATV rewiring??
Hey guys... i was cruising around the classifieds and found what i think could be a decent deal.... there is a 110cc giovianni ATV... but it has a couple issues... 1 is electrical.. it will start if you jump from the lawn tractor directly to the starter.. but wont run turn key..or by jumping the battery apparently..so rewiring i assume is what needs to be done...
Also it is missing the chain tightener bolt..which i assume i can use any bolt.... he was asking $200.. but will take $175 for the bike... Thoughts on if its worth it... and/or any known fixes for these issues if they are common........ Thanks for all the Help Guys.. Cheers Leines |
Well it would be quite funny if that guy didn't know you have to grab the brake before it will start, could be as simple as that, but if it will start from another 12V source then just checking the wiring would be an easy task, the manual for my 50cc has the wiring diagram, i would check if he has the manual and see if the diagram is in there. Could just be a bad switch somewhere, or a loose wire.
beyond just wiring.. if it started one day..and didnt start the next... what could be the issues... or better question..from the battery and the key..what is between that and the starter..as it starts directly to the starter.....
also is he correct in that i can use any bolt for the chain tightener bolt? like something i could get at any motorcycle shop..or from gio directly??? Thanks again.. |
#4 | |
If I was a gambler (which I'm not) I'd bet the farm that it's one wire pulled out of a plug and it's good to go. The trick is to find it. |
#5 | |
