06-03-2009, 06:29 PM | #1 |
GIO Puked
Hey guys..
Started up my QUAD, been sitting in the back yard for a while thought it needed a run. It started okay, I let it run for a bit then tried to give her some gas and it puked. Started up again, idled, when I move the throttle it puked again. Now it won't start. Think this is a gummed carb or something else? Gio 110cc Beast, pretty much brand new first tank of gas. |
06-03-2009, 06:41 PM | #2 |
Sounds like a carb problem. Starving for fuel.
Allen
06-03-2009, 07:30 PM | #3 |
Think I need to take it for a good 30-45 min burn to warm it up and burn through this old gas. I did get it started again after some hard work.
06-03-2009, 07:34 PM | #4 |
Sounds like its running too rich on idle. Try adjusting the idle air srew.
06-03-2009, 07:34 PM | #5 |
Usually cleaning out the bowl will get any junk that settle into out.
Allen
06-03-2009, 07:50 PM | #6 |
Wow, good thing I bought that minkuni carb.
06-04-2009, 07:57 AM | #7 |
Todays gas goes bad pretty quickly. Could give the same symptoms you are haveing.
06-05-2009, 02:49 AM | #8 |
I actually think it was/is the gas. The gas I had was some year old lawn mower gas I had kicking around here. It's been sitting in there for a while. I do start it up every other day but it hasn't been on a good run to keep things flowing.
It's been hot as well here the past couple days, so the carb may need some tweaking. It does seem to run a bit rich, smells so anyways. I took it for a spin tonight at dusk around the neighborhood and through some fields. (nobody around) and got 'er warmed up. Seemed to be okay. I did notice the front wheel seems a little wobbly... nut is tight with pin in it still so perhaps that crap bushing/spacer isn't true. Anyone else have this problem? |
