01-29-2009, 11:26 AM | #1 |
Zongshen Sierra oil leek or not ?
Hi
Im regularly changeing my oil in my zongshen, every 3 months or 4 000km. Every time i put 1 liter of oil. Today i replaced oil after 3 months of riding. When i was changeing oil i noticed that there was smaller amount of old oil (<1 L). So i took the old oil and put it in plastic bottle with measure scale, and it was only 0.9 L of oil. So my question is, is it normal to loose 0.1L oil in three months of riding (about 3 000km) ? Sorry for bad english :oops: Thanks |
01-29-2009, 11:56 AM | #2 |
I would say you are doing really good. These little engines are worked hard so a small amount of use like that over 3-4K kms is pretty low. I tend to change every 1-2K kms. I run mine hard and will see alittle bit of oil use in that time.
Allen
01-29-2009, 02:18 PM | #3 | |
Re: Zongshen Sierra oil leek or not ?
Is your Zongshen 200GY-2 still running well? How many miles have you traveled on it so far? Spud
01-29-2009, 03:21 PM | #4 | |
By the way, motorcycle is running strong, excellent bike :P [/quote] |
01-29-2009, 03:35 PM | #5 |
If I remember correctly, someone else had a similar problem with their speedometer. The needle was loose on the shaft it rides on. Maybe a little glue to secure it again?
01-29-2009, 03:37 PM | #6 |
I opened the speedometer, here is what i found :( , a small light bulb 5W inside the speedometer generated too much heat has melted the odometer plastic numbers. So i recomend you to replace the regular bulb with LED one before it happens to you.
Normal Burned |
01-29-2009, 04:53 PM | #7 |
Yep the oil usage is normal. Nice find on the odometer!
2009 XR650L Big Red Pig Tusk bar risers 2007 X-Moto(Jetmoto) GY250 --mods--- 15/40 sprockets UNI Pod Filter 2007 Shineray TMS 200XYi--Betsy Betsy Mods:______________________ Acerbis DHH headlight FMF Powercore pipe Uni Pod Filter |
01-29-2009, 11:15 PM | #8 | |
Thank you for posting the tip concerning the melted odometer wheel! I believe my Zong speedometer was originally illuminated by two, 3-watt incandescent bulbs. However, after they burned out I replaced them with two LED bulbs. In addition to being cooler, the LED bulbs I purchased are brighter and much more resistant to the harsh vibration I encounter when riding in the dirt. I got my LEDs from the following vendor: http://www.superbrightleds.com/specs/bulb_specs.htm My speedometer uses wedge base bulbs. Therefore, I bought the WLED-W4 bulbs, and I love them. Spud
