02-18-2007, 01:48 PM | #1 |
Skid Plate
I took my skid plate off due to some vibrations I was getting, and I was wondering does it really matter to have it on there. I guess it would matter more whenever you go off roading. That's my guess. I'm game for some opinions.
02-18-2007, 03:24 PM | #2 |
well i would recommend leaving it on, therefore rocks, debris etc wont hit the motor. I can also assume its to help keep grime from caking up under the motor and frame...
Why did you want to take it off? stage 1 weight reduction?? :roll:
My name is Justin, my friends call me Stix. 2008 Kawasaki KLR650 Candy Lime Green ______________________________ I am the official China bike registration Guru For the State of Maryland..... HA. |
02-18-2007, 06:25 PM | #3 | |
Re: Skid Plate
02-18-2007, 11:00 PM | #4 |
Put it back on, if they didn't work then 90% of all enduros wouldn't have them, you dont wanna crack your crankcase... Go to Home Depot and buy a tap and dye kit, not that expensive and you may need it for other stripped bolts. Replace with the appropriate size bolt/screw and add a lock washer, your crankcase gets pretty hot and it's a better fix than loc-tite.. You can drill a hole in your skidplate if it bothers you that much to take it off to change oil, I rock my bike from side to side when draining oil to get all of it out, you'd be amazed how much more comes out... They also make High Temp rubber washers, throw a couple of them on there...
02-19-2007, 12:01 AM | #5 |
where can you get those rubber washers?
02-19-2007, 09:37 AM | #6 |
Home Depot, Lowe's or many auto part stores..
04-27-2007, 01:06 PM | #7 |
Yep I just stripped the skid plate bolt too. Going to cut out a hole in the plate for oil changes. Get a simular bolt and use a different type of locktite. It's red permenant bolt gripper.
Got rid of my head light area squeek, the wires were rubbing against the fork. I carefully bundled the wires, and used a zip tie. No more squeek when I turn the bars. The wires still have enough slack, nothing is being pulled on when I turn the handle bars, and all my lights work. |
04-27-2007, 01:30 PM | #8 | |
04-27-2007, 02:58 PM | #9 |
I don't bother with the kick start as I don't have too much faith in the manual, who knows it may work... I do know exactly how much oil I put in and I get the same amount out when changing it...
06 Lifan 200 GY-5 |
04-27-2007, 03:04 PM | #10 |
When I put mine together, I took both the kickstart and the skid plate off. I knew the intended purpose for mine from the beginning (Roketard). I don't plan to stall in the mud(with a dead battery) or high center on a rock or stump any time real soon :roll:
2008 Jonway MC-70-150 2007 Roketa DB-07B (RSM-200E) 2006 Roketa DB-07A (RSX-200E) 1995 Kawasaki Concours (ZG1000) |
