Old 07-24-2008, 04:48 PM   #1
glenski   glenski is offline
flushmount turn signals
Anyone out there install a set of flushmount signal lights? I am thinking I would like to make my own or buy a set or something. One of the rear ones is broken after an offroad adventure (just a note the tusk bark busters do an excellent job of busting rock as well).
I am thinking some cab mount lights might work? I want cheap and something that won't break next time I fall because I will fall. It is just the way I ride!
Thanks,
Glenski
Old 07-24-2008, 05:19 PM   #2
AZ200cc   AZ200cc is offline
http://www.1tail.com/sa/cart/category.asp?cg={7C408199-F011-4CD4-A109-636F5004E0CF}
Quite a few choices out there, Hope this helps.
<br />2001 Suzuki DR200SE<br />1997 Suzuki RM250 YIKES<br />1995 Yamaha Breeze 125 daughters<br />1991 Honda XR80r Restored<br />maybe a 2003 Yamaha TTR90
Old 07-24-2008, 05:52 PM   #3
ImEazy   ImEazy is offline
I changed mine to flush mounts. They work well.
I got them at the local dealership for around $18. You can find them on
ebay as well. Just do a search for "flush mount turn signals". There are
many different kinds and sizes. I had to drill two holes and use a couple
of rubber washers I had as spacers so they would sit flush. you can see
what I mean in this pic. Hope this helps.
Left rear signal...
Right rear signal...
With the tail section installed...
2000 MZ Baghira
Old 07-24-2008, 05:54 PM   #4
Thanks, those look nice on your bike. The tail section of my Lifan doesn't really look like that though. I went out and had a look around tonight. I am not even sure where you would mount them on a Lifan such that they could still be seen with luggage on.
Old 07-24-2008, 06:09 PM   #5
maf119l   maf119l is offline
Send a message via Yahoo to maf119l
Check with a truckers chrome shop.Lots of choices and most LED's are usually $20.00 or less.
yamaha vstar 650,unknown chinese 4 wheeler,johnny pag 250 spyder,lifan gy-5
Old 07-24-2008, 06:59 PM   #6
srreynolds2003   srreynolds2003 is offline
I got a set from Lee's Cycle $11 shippied to my house. I have not installed them yet. so when I do I will post photo.
http://motors.shop.ebay.com/merchant/leescycle
-2005 Sierra SR200-
Old 07-24-2008, 07:44 PM   #7
I went to Canadian Tire tonight and bought two cab mount LEDs for $10 each and some electrical tape and some connectors. I came home and think I have found a way to mount them such that they will still be visible when the rack is loaded with luggage.
I am not really sure how well they will work but I presume they will be okay and won't flash too fast or anything like that. They are just a plain old 12V LED. I know the stock bulbs are 10W each, not sure what the LEDs are for wattage.
They only have one wire coming off of them. I think that is the wire that would connect to the "red" wire from the existing and the "black" wire from the existing will just be bolted to the fixture itself to form a ground.
Old 07-24-2008, 07:56 PM   #8
Correct.
Old 07-24-2008, 11:40 PM   #9
forchetto   forchetto is offline
I've heard somewhere that you can't simply swap incandescent bulb turn signals for LED ones without changing the flasher unit for a special LED one, or alternatively use a load equalizer like this one:
http://www.bikerhiway.com/universal-...zer-p-235.html
There are others here, as well as being cheaper the page has more useful info on converting:
http://www.customled.com/PRODUCTS/TH..._equalizer.htm
This is a thread on another forum with lots of explanations and tips. It seems that the fancy named "load equalizer" is nothing more than some power resistors on a heatsink, rated so the old flasher unit keeps on thinking it's a normal bulb.
http://www.kawasakimotorcycle.org/fo...equalizer.html
Something like this:
This site has both the flush mounted lights and the equalizers:
http://www.ezeran.com/main.sc
Jincheng Monkey JC50Q-7 (two of them)
Skyteam Dax replica ST110-6 (two of them)
Zongshen ZS125-43
Qingqi QM200GY-BA Super Motard
Yamaha Virago XV1100
Triumph Bonneville SE
Qingqi QM110GY
PGO Bug rider 250 Buggy
Old 07-25-2008, 12:59 AM   #10
tigertamer   tigertamer is offline
Here is my setup: the front "winkers" (gotta love Chinese terminology) are flush on the barkbusters. The rear were originally mounted directly to the tail light assembly, I moved them later to this new position so they will be easier to see from behind. The tail light also has a moto clearance license plate bracket .
Mine do not blink too fast. In fact they blink quite slowly...on for about 2 seconds then off for about 1/2.
07 H-D XL883C
06 LF 200GY-5
Yin and Yang
CAUTION
Obey The Traffic Regulation.
Always Wear a Helmet.
Don't Ride After Drinking Wine.
Before Operation, Read The Owners Manual Carefully.
Old 07-25-2008, 03:57 AM   #11
The conditions aceptable in the UK vehicle inspection, for example, is that they must flash at a rate of between one and two times per second (60-120 times per minute), so yours would probably be failed there.
WHAT do you carry in that box?
Zongshen ZS125-43
Qingqi QM110GY
Old 07-25-2008, 09:16 AM   #12
katoranger's Avatar
The flasher (capacitor) requires a certain rate of drain to work correctly. If the new LEDs have a similar wattage as the stock bulbs they should blink at about the same rate. Typically an LED pulls less watts so you end up with slower blinking rates.
Solution is to change the flasher with one rating for less watts. (Like Forchetto mentioned)
Allen
