Hello everyone
Bought a 2020 RPS hawk from a powersports company in 2020, to powersports if I recall, Methheads stole it in LATE 2020 and I recovered what was left of it in 2021 and rebuilt it in summer 2021 From scratch, It then spent 2022 in Michigan over that summer and then I left it covered during the winter but due to personal issues I was not able to return until 2024, I sadly did not winterize it. When I resurrected her in late spring 2024 she had a gallon of water in the oil tank, the oil had separated not sure how the water got in there , we redid her with fresh oil and now she has a “no spark” condition, but she does crank over so the motor is not seized at all, I just checked the first stop after the plug (the wire looks in good condition) when I try to turn her over I see resistance on my meter coming off the wires at the “stator”????, I’ll take pics . Right now it could be a stator, CDI, regulator, battery possibly, but that wouldn’t stop the spark if we cranked it , so I’m at a loss. I don’t want to start throwing parts at it until I have a good idea where to start Thanks for any suggestions |
Do we not have anymore hawk riders/aficionados in here anymore?
Check that you coil has a good ground to the chassis. Also check that you didn't accidently hit the kill switch. many of us have been guilty of doing that including myself.
#4 | |
Definitely!
************ ![]() ![]() ![]() ![]() -2022 Lifan KPX250 -2023 Hawk X -2022 Brozz Recon -2021 Raven 250 -2022 RPS Condor w CG250 -2020 Hellcat (whitey) w ZS190 -2012 Suzuki DRZ400 - Bunch of other $heet with wheels and tracks THATS RIGHT! MotoCheez on Youtube. http://www.youtube.com/MotoCheez MotoCheez Website. [URL="http://www.motocheez.com[/URL] |
It has an AC style CDI if it's the carb style, so does not need a battery to run. First I'd make sure the wiring is good, then test with a brand new plug for spark, Then the CDI is a cheap to buy to eliminate if it's that
Thanks guys I’ll start with the plug. Maybe it’s just old
New plug, no spark , all grounds good, power to speedo cluster , no broke wires that I can see, I’m eying the CDI, should I just buy new CDI, coil, and regulator and just cover all bases , or can we test further
Btw battery is likely shot, but shouldn’t interfere with spark |
Anyone , I’m looking at CDI boxes but not sure how many pins are on it, I’m thinking of just swapping regulators , cdi and coils, no one here seems to know much about these anymore , except motocheez of course
Ok ordered an ignition coil, let’s start there
