Idling way to high
I put a new Nibbi PE30 carburetor with #40 pilot jet and #140 main jet and a pod filter on my bike and when I start it, it idles extremely high. When adjusting the idle screw, I have to back it almost all the way out for the idle to come down just a little and the pilot screw has to be backed out 1/8th turn. I’ve tried adjusting the throttle cable, even took the throttle off the carb to make sure the slide sits all the way down and nothing changed. Engine gets hot very fast and the exhaust was glowing red at one point. Not sure what to do? Any ideas?
#2 | |
It’s a Xmotos XB88
Does the engine speed up even more if you turn the handlebars to the right? If so, there's a good chance there isn't enough slack in your throttle cable to allow the carburetor slide to come down against the idle speed screw.
-2024 CSC TT250, stage 3 motocult kit, Nibbi PE28FL with custom-made cable controlled choke, modified stock muffler (larger diameter tailpipe), custom oil cooler installation with relocated stock evaporative emissions canister, oversized stainless steel footpegs, IMS folding tip shifter, a few little blingy bolts and bits. More personal preference mods to come. |
I even took the throttle cable off to make sure the slide is all the down
The slide is probably installed backwards. Look to see if the slides all the way closed. If not, take it out and rotate it 180°
It is all the way closed
The slide will only go in one way, I tried to adjust the throttle cable to see if it was getting hung up and nothing changed. I took the throttle cable completely out of the carb so the slide definitely sits all the way down and the Idle is still really high. turning the idle screw counter clockwise does hardly anything until its almost all the way out. Turning the pilot screw clockwise does nothing until its 1/8th turn out.
The symptoms do suggest stuck slide, and I thought that you cannot even screw on the cap to close the tower if the tab isn't aligned with the slot in the slide tower.
I believe what you are saying, the only thing I can think of causing high idle is the slide not closing all the way. I don't think an air leak or airscrew could cause a high idle. You jetting seems in the ball park, certainly the pilot (#40). Maybe, just maybe try a #42 ?? I've gotta vote with Jerry on the slide though. It's the elephant in the room ![]()
For reference:
https://www.xmotos.cz/gb/motorcycles...c-4t-2118.html
#11 | |
The old (stock) carb would only work if the choke was on, like it wasn't getting enough air and would stall when you took off choke. It also wasn't serviceable, the bowl was held on with rivets so I had to get a new carb
#14 | |
#15 |
I was thinking about lookin in to the valves, but that's way out of my league. as far as the RPM there is no tach so idk the exact RPM
