Old 09-24-2023, 06:34 PM   #1
Landshark77   Landshark77 is offline
What motorcycles have Zongshen NC250
I see the GPX fse250r has it but what other bikes in the US have that same engine? Also looking for bikes with the nc300s engine.
Old 09-25-2023, 07:52 AM   #2
SSR
http://www.ssrmotorsports.com/store/...bike-index.php
Old 09-25-2023, 08:57 AM   #3
Trailmaster has the TM38 with the NC300 water cooled OHC engine. This is the single OHC version, with 298cc displacement, 6 speed transmission, makes about 31hp. ~$3800 from Family gocarts, for instance. Fully adjustable KKE suspension like the Temp X.
THis TM38 is at the top of my list at the moment. I might sell the Templar and get one. No lights, but there are kits to make it street legal.
Old 09-25-2023, 01:08 PM   #4
Thanks I'll have to check that one out!
Old 05-28-2024, 01:15 AM   #5
BBQKidd   BBQKidd is offline
BBQKidd's Avatar
Thumper, do you know where to get the kit to make the TM38 street legal? I have an EGL NC300 A17 that I would like to buy that kit for. Thank you!
Old 05-28-2024, 07:43 AM   #6
I think the TM38 has an ignition key. I added one to my KTM and got a 1PZ SR1-H01 kit that came with a variable turn signal flasher, horn, and a 7/8" handlebar switch cluster (under $20). I got led sequential turnsignals, and small Quasco rear led turnsignals that have three way lighting (turn, running, brake). I also got a fender mounting tail light that has brake/running/license plate illumination.
There are many options out there, but I had to design and fabricate wiring. I kept the system isolated from the bikes magneto type ignition (always on, with kill button) except that I patched the ignition swith into the kill button circuit. In the on position, the ignition powers the DRL, tail lights, horn, turn signals, and a separate handlebar switch for the headlights. I have the battery isolated from the bike, but has a battery tender lead to rechage the Lithium battery (no regulator rectifier). I got a polysport H4 type headlight assembly that has DRL and an H4 type halogen bulb, but I replaced the bulb with an led hi/lo element for lower power consumption. So I will charge the battery in the garage via the battery tender connection.
This guy went with a kit from Street OHV:
There are other options out there.
Old 05-28-2024, 09:57 AM   #7
red2003   red2003 is offline
Or, just go with the TM38EX that already has all the on road stuff.
Old 05-28-2024, 10:42 AM   #8
You took the words right out my mouth. I've been eying the TM38EX for a while.
Old 05-28-2024, 11:19 AM   #9
BBQkid just needs a lighting conversion plan.
He is asking about his EGL NC300 A17 (in post #5).
I just put that TM38 video up since the lighting conversion would basically work the same way. There are partial/full kits. Street OHV has a complete options build thing on their website. I used a 1PZ kit.
Old 05-28-2024, 12:01 PM   #10
In post #3 it sounded like you weren't aware of the TM38EX, that's why I mentioned it.
Old 05-28-2024, 05:41 PM   #11
BBQKidd's Avatar
That's super helpful. Thank you!! My EGL came with an ignition switch. I really just want to sort a rear brake switch and rear brake light. I also plan to wire in an instrument panel just like the one I have on my X-Pro Templar, which I purchased on Ebay. I don't think I will do turn signals because I will be mainly using this bike on Backcountry Discovery Routes, which are mainly dirt but do require the bike to be licensed for the street. Cheers!
