Old 08-31-2023, 10:38 AM   #1
HotRod77   HotRod77 is offline
Oh No Venom Ghost Cruiser 250cc not starting
Hello,
I have a Venom Ghost Cruiser 250cc, also known as a DongFang with 126 miles. I am having trouble getting the bike to start. Engine turns over with no problems and battery is charged. I have compression and fuel but I am not getting spark. Spark plug is new NGK. Checked the coil with a meter on ohms and reading was okay, but swapped with a spare coil and same result. I have also swapped out the 6 pin CDI box with no result. The stator tested 159 ohms across the ignition circuit, and 0.4 ohms across the two wires that charge the battery. I have followed all of the wires and found no breaks, cuts or burns in the wires. Fuse is new. All lights and switches on the handlebars function as they should.
What else gives the spark plug spark?
Also, is there any wiring schematic for this bike?
Thanks for any help
Update:
Bypassed the kill switch
Bypassed the switch on the clutch lever
Installed new stator
Installed 3rd ignition coil
Installed 3rd CDI box
kickstand in the up position, (does not have a switch on kickstand)
ensured battery is fully charged, also have charger on battery while cranking
Still no spark
Last edited by HotRod77; 09-06-2023 at 05:47 PM. Reason: Forgot to add second question.
Old 08-31-2023, 10:49 AM   #2
letsride   letsride is offline
"What else gives the spark plug spark?"
I know this may be slilly but, The kill switch and if there is a kick stand safety switch.
My Stable- 2022 Lifan KPX250 , 2023 Royal Enfield Himalayan, 1992 Honda GL1500 Goldwing, SSR 70 Auto, Kymco Mongoose 90, Honda Four Trax 300
Old 09-06-2023, 05:30 PM   #3
No safety switch on kick stand. kick stand is currently up while starting. Kill switch has been disconnected to rule out possibility of being bad
Old 08-31-2023, 07:53 PM   #4
Barnone   Barnone is offline
Barnone's Avatar
This place has Dong Fang owners manual/ wiring diagrams
Recommended for the following models
DF250RTS
DF250RTR
DF205RTG
DF250RTD
DF250RTF
Venom X22R 250cc
Ghost 250cc
Retro / Sportster 250cc
Villain Harley 250cc
CXR 250cc RTS
https://www.vaderparts.com/products/...lectronic-copy
Old 09-06-2023, 09:22 PM   #5
Barnone's Avatar
So this bike has 126 miles on it so it has run. What has happened to the bike since its last run?
I have an owner's manual so I will look at the wiring diagram to see if I can see where there might be a problem.
Old 09-07-2023, 07:50 AM   #6
Check to make sure you are getting power to the CDI and continuity from the CDI to coil. Make sure coil and CDI is grounded properly. It's possible that you might have a bad ignition switch or power not getting to ignition switch. You will have a 6 pin DC CDI.
https://offroadofficial.com/6-pin-cdi-wiring-diagram/
Old 09-07-2023, 09:08 AM   #7
I have thrown the key switch out, and jumper two of the four wires to give the motorcycle power. Red and black power on the motorcycle, the green and black with yellow stripe are loose. I am not sure what the black and yellow stripe are suppose to go to, but I have tried both ground and 12 volts with no results. I have 12 volts at the CDI. There are two wires on the coil, red with white stripe goes to the kill switch, and green is grounded to the mounting bolt at the coil. Disconnected the kill switch and left it out of the bike. Having a hard time trying to figure out what gives the coil power. If one wire is grounded and the other goes to the kill switch, where does it get power?
Old 09-07-2023, 09:11 AM   #8
CDI is a 6 wire, but only uses 5. It has 12 volts on one black wire coming into it, 2 wires go to stator, 1 wire to ground, and I dont recall where the last wire goes to. The coil has two wires on it, one that is grounded, and the other to the kill switch. I am having a hard time understanding where the coil gets its power from.
Old 09-07-2023, 09:17 AM   #9
The coil gets it's power from the CDI. Yellow wire on the diagram. My X22R and Venom Ghost only use 5 wires too.
Old 09-07-2023, 09:44 AM   #10
I do not have a yellow wire on the coil. It only has a red w/white stripe and ground wire on mounting bolt.
Old 09-07-2023, 04:08 PM   #11
I bought the bike non running in hopes I could fix it. Lost the keys for the ignition. Key ignition has 4 wires. Currently has the red and black wired together to provide power to the motorcycle. I am assuming the green wire is ground, as all are, but not sure about the black with yellow stripe
not starting, venom ghost, venom motorsports, venommotorsports
