Old 07-27-2023, 04:13 PM   #1
Ten85   Ten85 is offline
Ten85's Avatar
2022 RX3 Mystery rattle 6000rpm-8000RPM Help!!!
Good afternoon everyone. First time posting and using a forum. Bear with me. I bought a 2022 CSC RX3. I have produced a rattle vibration and i cannot put my finger on, it might have always been there cause i did not notice it until after 500 miles when i starting brining the RPMS up. I have absolutely checked everything i can think of. Around 6k-8k i get loud rattle where i am bout to wear ear plugs. I checked all engine mounts, engine guards, skid plate every bolt i can see. I pulled the exhaust just to make sure they installed an exhaust gasket. It was there but i still replaced it anyways. Could not find my stethoscope so used a screw driver. Engine feels smooth, the most noise/vibration i can find it right on the exhaust, but still not sure. i pulled off the skid plate and heat shield and the noise was still there. I took it to a local motorcycle shop to make sure it was not engine noise. They said the engine sounded fine, but i cannot find this rattle it is driving me nuts.
Rattle is there in Neutral, its there with clutch lever pulled in, its there moving or not. Has anyone had a similar issue.
Thank you for your time.
Old 07-27-2023, 06:15 PM   #2
bigdano711's Avatar
My guess is to check the valve lash...might be loose?
Old 07-27-2023, 06:55 PM   #3
Ten85's Avatar
Valves are good. That what i thought maybe. First adjusted them to .08 mm went back and put them at .06 mm and all is good there.
Old 08-02-2023, 12:17 PM   #4
Ten85's Avatar
Found out what it was. Engine was bad and blew up 400 miles after this post. Sounds like a crank or rod. CSC is sending me a new engine. Fantastic customer service. lets hope this engine is not bad..
Old 11-06-2023, 08:31 PM   #5
outboardr   outboardr is offline
Are you back on the road with the new engine?
Old 08-02-2023, 09:42 PM   #6
bigdano711's Avatar
I was gonna suggest plastics, 'cause mine rattled pretty loud at certain RPM's until I found that forward bolt and cinched it down.
