Some of you already know I've been trying to get the 167FMM in my CCW Heist running with no luck.
In the meantime I've also been searching for a replacement engine just in case. Found one local on marketplace, but curious if it will be a direct bolt in or if there are any differences (all these things look to same to me lol). I figure it might be worthwhile if I can get it on the cheap |
How much,and is it a runner.C
Check compression!
Seller claims it came out of a running ATV, which already sounds shady (why pull it then?)
I'd definitely want to see it crank with my compression gauge before making an offer. |
If it came out of an ATV then it likely has 4 forward gears and a reverse.
as Mudflap suggested, if its from an ATV it likely has a reverse gear.
looks to be a 250cc. Has Zongshen branding on the case covers, but the engine serial number does not begin with ZS... ok for parts or an ATV/gokart transplant. |
