02-01-2023, 08:41 AM | #2 |
Center stands have become rare throughout the bike world. I have a Dongfeng 250 RTG, a Kawasaki Z650, and a Suzuki C50 -- 'nary a center stand among 'em.
02-01-2023, 07:14 PM | #3 |
Center stands or even the mounts for one have become rare indeed I don't think the RX4 even has a place for one.... (mounting points) but there is an after market center stand for the RX3 that is supposed to be able to work on the RX4 and it might be worth investigating.
worse than the missing center-stand is the good old Kick starter ! because Now you have to keep a good battery in the bike, if you don't you have no way of starting it ! I went out to start the RX4 a bit ago thinking it's been over 2.5 months sense it last ran and the battery was dead.... not a good reflection on CSC at all... it's on the charger now and hopefully I'll start it tomorrow. the battery died the 1st month on the TT250 but who cares you can kick start it right? not so with the RX4..... with the battery being such a vital part of the bike on a RX4 you'ed think they would give you a good battery with the bike but this one has lasted only a year..... pirty pathetic. Bob........
It's too late when you've gone too far ! |
02-02-2023, 11:26 AM | #4 |
If you look at the RX4 frame you will see that there are no good mounting points for a center stand. On the RX3 it is possible to mount a center stand using lugs which are present from the factory...they were used during assembly of the bike. The RX4 does not have those lugs...because there are no frame rails under the engine. The bash plate mounts directly to the engine block for the same reason.
As for the battery, we all know that Zongshen cut corners to keep the price down. That's not unique to Zong, lots of other low cost bikes have the same 'feature'. The same goes for the suspension bits and the chain (although I think the chains are now much better than the early RX3 models). Since there is a constant parasitic drain on the battery it's unrealistic to think the battery will retain a charge for months at a time. Finally, my TT250 had a kick starter and that sure was handy. It helped that the compression ratio was only 8.7:1 so I could spin it pretty easily to start even when dead cold. The RX4, on the other hand, has a CR of 11.0:1. Even with the automatic compression release I think I'd be hard pressed to spin that lump fast enough to fire. Even if I could do so, the fuel pump needs electrons to work so my efforts would be wasted. |
02-12-2023, 03:06 PM | #5 | |
parasitic drain...
I guess I was lucky, never had a problem with its battery, yet (still using stock battery: RX4 2019-20). I will be getting a NOCO soon though. |
02-13-2023, 11:13 AM | #6 |
The clock is constantly draining a tiny amount of current from the battery. The ECU is probably sucking a few electrons too, just to maintain settings. My '21 RX4 is still running the OEM battery and I intend to replace it soon, not sure i want to go the Lithium route. A good friend had his whole shop (motorcycle dealership) destroyed when a Lithium battery caught fire.
02-15-2023, 04:57 PM | #7 |
Peter,
That's a very legitimate concern, tell us more? The Noco, like CSC, deserves a fair shake though. The packaging is grade A+ imho, instructions too, and the battery itself exudes quality. I have not used the smart genius charger I got from them, but I can say both my RX3 and RX4 crank/start instantly now. Your choice of course, but thought I'd share the links. https://no.co/products/lithium/powersport https://www.amazon.com/dp/B091P9QXX7...roduct_details |
02-03-2023, 02:20 AM | #8 |
Math Teacher that owns bith RX4 and RX3 tipped us off that Noco makes lithium batteries that fit our Rx4
I got mine off Amazon for both of my RX’s, instant starts now https://www.amazon.com/NOCO-NLP14-Po.../dp/B091P9QXX7 |
02-21-2023, 06:24 PM | #9 |
My Ural and my three Ice Bear 150 scooters all have center stands but my 2022 Dong Fang DF250RTG that is coming to me soon does not have a center stand. Wish it did!
02-22-2023, 08:37 AM | #10 |
It would be great if a jack wasn't required to get the Ural up on its' center stand.
03-11-2023, 09:59 PM | #11 | |
I carry the block in the trunk of my Ural. Last edited by Barnone; 03-13-2023 at 02:16 PM. |
