11-25-2022, 10:20 PM | #1 |
New X-Pro Templar 250 rider
Hello, new Templar rider here. I’ve got about 400 miles on mine. Dayton, Ohio area, for farm use and errands and fun. Plated and insured, I got a big cheesy windscreen on it and a 16T front and I want to get to 70mph sometimes so I’m wondering what everybody thinks I should rejet the carb to, or what aftermarket carbs would be recommended? Thanks.
11-25-2022, 11:21 PM | #2 |
They will probably recommend you change the rear sprocket to something smaller or get a larger front. How hard was it to mount that windscreen?
11-26-2022, 12:49 PM | #3 | |
I’ve got a 16T front and I’m getting to 67mph but I need about 10% more power. I can hit 55 in 4th, so I know the gearing is good. |
11-26-2022, 07:10 PM | #4 |
16T front sprocket is the largest I’ve heard put on the Templar. Did it fit without too much trouble?
11-27-2022, 11:23 AM | #5 |
Considering how much custom fitments (figments?) I have to imagine and create to get my farm and tractor equipment to work, plus the other 5 vehicles and dump trailer and everything I have, this was a cinch. Main problem was my anxiety about removing some essential things like maybe a wall for an oiler cavity, but it moves great and makes no additional noises so I’m hoping it’s running happily inside its new home.
First road ride X-Pro Templar 250M https://youtu.be/k3kA_JZEGyk Windscreen: EGO BIKE Smoke 18*16 Tinted... https://www.amazon.com/dp/B019Z6VA4Y...p_mob_ap_share 16T 520 front sprocket: WPHMOTO 520 20mm 16T Chain Front... https://www.amazon.com/dp/B0865YF176...p_mob_ap_share Simple, cheap exhaust wrap: Titanium Exhaust Wrap 1" x 16'... https://www.amazon.com/dp/B073ZBF72X...p_mob_ap_share |
11-26-2022, 06:59 PM | #7 |
Temp M comes with the venerable, and AWESOME ZS172FMM-3A (visible on the stamp behind the gear shift). It has a 13T front sprocket.
I had to grind down the cast alloy shroud just to mount a 14T 520 sprocket. Can you a pic of your 16T (!) mount?!? It must be TIGHT! Last edited by Thumper; 11-27-2022 at 08:14 AM. |
11-27-2022, 11:15 AM | #8 | |
11-27-2022, 11:12 AM | #9 |
Hello! Thank you.
11-26-2022, 07:08 PM | #10 |
You won’t increase horsepower by rejetting the carb. Your top end speed is reduced by the things you are hanging off your bike, panniers, bags, windscreens, tall and wide riders etc.
If you want to increase horsepower you need to put more fuel and more air into a given volume of engine. Fuel is easy to increase, air is more difficult to get in. Think super charger, turbo charger, nitrous oxide, etc. to get significant air increase to get a noticeable horsepower increase when fuel is increased. Or an easier way install a larger cylinder and piston to increase volume inside the engine at normal barometric pressures. Or the easiest way, buy a bike with a bigger engine already in it. What you can do is play with shifting the torque band left and right across the existing horsepower band by retarding or advancing the timing—what you gain on one side you lose on the other side. You’ve already played with the gearing. In generalization a tooth change in the front sprocket is equal to three teeth change on the rear sprocket. I don’t have an M but having an X I was impressed you got a 16 on your front. Our X’s can go up one tooth on the front sprocket and that’s it with or without some grinding required to get clearance. I got a 40 tooth rear and will leave my front factory 13 teeth. If you notice going down 49 rear to 40 is a 9 tooth change. Going up 13 front to 16 from is a 3 tooth change and multiply by 3 and you get 9. Same effective net. If your throttle response is bogging, or stuttering or the bike is popping on deacceleration you can clean those up with rejetting your carburetor. With the X it’s usually running lean out of the box I bumped my jets from #120 main to #125 main, #40 idle to #42 idle; and 1mm needle shim. In general you want it to run stoic to a little rich. Rejetting or buying another carburetor is not going to make you faster in your top end or give you more horsepower.
11-27-2022, 11:19 AM | #11 | |
As for tall and wide riders, I’ve tried washing myself on cold and drying myself on hot, but it doesn’t work.
carb, carb rejet, carb upgrade, carburetor, templar |
