Old 11-21-2022, 05:18 AM   #1
Dblack5939   Dblack5939 is offline
Doh! 2022 Vitacci Clash 200 EFI
I have this Clash 200 efi and since I first started and road it, I was smelling a burnt oil smell. I assumed that it was because it had some kind of break-in oil in it... after my first oil change I still noticed that it would give off that smell still. Now, I'm at nearly 1000 miles and I've noticed that there is oil in the time that comes out of the air filter. Also, my bike stalls in motion sometime and when I come to a stop, it often keeps ramping up and down. What do I need to do? Thank you
Old 11-21-2022, 10:10 AM   #2
Mudflap   Mudflap is offline
Oil often gets into the air box during shipping when the crate isn't kept upright. Open the air box and clean it out. Also make sure the air filter element isn't soaked with oil.
Is the oil level correct?
Does the check engine light ever come on?
Old 11-21-2022, 03:34 PM   #3
clash 168cc   clash 168cc is offline
Make sure you changed the gear oil too. You may have overfilled. May also have a small leak but definitely check the air filter.
Old 03-03-2023, 09:46 AM   #4
How do you change the gear oil and where is it located at?
Old 12-17-2022, 01:49 AM   #5
nazimsahigara   nazimsahigara is offline
Hi, I have Vitacci Force 200 EFI, the same engine as Vitacci Clash, Where can I find and purchase new muffler exhaust set for my scooter? Any leads?
Old 12-17-2022, 05:08 AM   #6
That muffler mount is quite different from the Clash.
Old 12-17-2022, 10:17 AM   #7
They have universal mufflers on Ebay you may be able to attach to your pipe. If you find any parts to these bikes. Be sure to post here.
Old 03-03-2023, 10:09 AM   #8
Look up GY6 gear oil change on YouTube. They're all about the same.
Old 05-10-2023, 11:15 PM   #9
ChroMiikey   ChroMiikey is offline
I've heard numerous reports of surging RPM and engine stalling with the Clash 200, and I'm very curious if Vitacci used a substandard TPS or fuel pump.
OP: Were you able to identify and fix the RPM issue?
Old 07-07-2023, 01:13 PM   #10
I've had that issue happening since my bike was new 🤷🏾
clash 200, clash 200 efi, clash problems, vitacci clash
