10-26-2022, 03:32 PM | #1 |
Weak Cranking coolster 125
So as the title states I have a cranking issue on my coolster 125. I have changed the starter, solenoid, battery.
Motor turns freely. Stopped cranking one day and fried the wire from the battery to the wiring harness. I traced the wire back and replaced it. Now it just clicks the solenoid but wont crank. That is when I started repalacing items mentioned above. I am at a loss. Any help is appreciated. |
10-26-2022, 04:00 PM | #2 |
Did you charge the battery? Make sure the battery is putting out enough voltage under load.
10-26-2022, 07:31 PM | #3 |
Yeah brand new battery. Even jumped it from my truck.
10-26-2022, 07:32 PM | #4 |
Sorry yes I did charge the old and new battery just to be sure.
10-27-2022, 09:03 AM | #5 |
Don't discount the fact that the new starter could be bad. I went through a couple before I found a good one. Below is my first new starter after a dozen starts. It was not properly wound or potted.
11-11-2022, 03:10 PM | #6 |
Cranking
check for a good ground from motor to battery...jump the starter termial from battery yo starter post...this is direct voltage...nothing in between...see what that does..put a good ground wire to battery mount...good size wire to handle load,...if it is good then..report..
