Old 06-09-2022, 06:30 PM   #1
Zmag803@gmail.com   Zmag803@gmail.com is offline
Vitacci pentora 250 sprockets
Not sure what fits? Bolt pattern measures 146 mm from bolt holes center, Yamaha raptor is 145mm, anyone have any sprocket experience
Old 06-11-2022, 06:13 PM   #2
Post a picture. Might be able to match it to a vehicle that one of the members has.
Edit: looking through the JT sprockets catalog shows the Yamaha ATVS (Raptor, Banshee, ect) all have sprockets with 145mm patterns.
http://www.jtsprockets.com/catalogue...search-results
You might want to double check your measurements otherwise you might find something looking through sprockets for the other Japanese manufacturers.
2012 Kawasaki Versys
1984 Honda Magna V65
2016 Rhino 250
2016 Tao Tao 125D
Old 06-12-2022, 01:47 AM   #3
TORKER   TORKER is offline
Yes, don't sweat it. Rear sprocket is Yamaha Raptor 250, YFZ 450. Front sprocket is JTF 328.
If you need info on these, I may be able to help in some aspects since its mostly based on the YAMAHA RAPTOR 250. I'm racing mine and still researching what works. There is some good info on here about it as well. Engine is (mostly) CRF230F. The key word here is MOSTLY. I hope that helps.
TORKER
Old 06-12-2022, 08:03 PM   #4
Thank you all for your input, just grabbed a Yamaha sprocket, works great, went down to a 38t get a little more speed for the boy
Old 07-21-2024, 12:14 PM   #5
Dylan9393   Dylan9393 is offline
TORKER
What about an arms? Are the raptor ones compatible? Also what’s a good clutch?
Old 06-13-2022, 06:50 PM   #6
Glad to help my friend.
TORKER.
