11-03-2021, 11:16 AM | #1 |
Shade Tree Fabrication
A place to post your home made mods that might be useful to others.
11-03-2021, 11:20 AM | #2 |
Adjustable air mixture screw
Most of mine have been posted elsewhere but I wanted to try to collect as many as possible in one thread.
This air mix screw is available on ebay or amazon, cut a slot in the factory break off screw so you can get it out with a flat head. Cut the air mix screw off then file it down into a flat heat. JB Weld the two together, now it's easy to adjust air fuel mixture while test riding. This one definitely helped me get the bike running really good. |
11-03-2021, 11:34 AM | #3 |
Silencer Tip for open exhaust
I made a baffle out of a piece of aluminum pipe off of a piece of furniture, also wrapped the exhaust tip with as much header wrap as I could fit under the plastic. Turned the tip into a silencer. It works good, still sounds throaty and deeper, it’s still a bit loud but way better.
11-03-2021, 12:23 PM | #4 |
Mesh body panels
I had an old screen laying around that already had velcro sewed on one edge, used industrial self adhesive velcro and gorilla tape on the other seams.
Obviously no body panel there since it's air cooled. It may retain a tiny bit of heat when sitting still, but I'm very rarely sitting still. I thought it would help keep more air coming in from the front cowl going across the jug, carb, airbox and exhaust. Maybe keep some debris from the road out and look cool. |
11-03-2021, 06:58 PM | #5 |
My Shade Tree Maintenece Mod
This is about as shade tree I got. Not really a bike mod but a moth pocket maintenance mod.
DIY Pool Noodle Cylinder Hone http://www.chinariders.net/showthrea...ht=pool+noodle |
11-04-2021, 03:02 PM | #6 |
Putting together an alternate setup for street only days. Wanted a shorty front fender and had to make the mounts out of aluminum. Since the forks are inverted, it had to mount to the guards. Just finished, haven't mounted on the bike yet.
Mounted this morning... Last edited by DualSportDude; 11-05-2021 at 11:40 AM. |
250 dual sport mods |
