08-14-2021, 06:22 PM | #1 |
Hawk DLX throttle has a mind of its own.
Bike was surging under throttle, held revs with clutch lever pulled between shifts,
had an extremely high idle Finally threw CEL, code p0123, TPS Got new throttle body with sensors from PowersportsMax under warranty (bikes at only 1600 miles) Installed new battery and throttle body Starts strong, CEL is gone, idles from 1500-2000, but breaks up under throttle and will stall when rolling to a stop. Que pasa? I just wanna ride guys! |
08-21-2021, 07:15 PM | #2 |
HVe you checked the valve lash?
04-11-2022, 01:27 PM | #3 |
do you know and aftermarket cable for hawk 250 dlx throttle cable
04-11-2022, 01:32 PM | #4 |
You may need to give it time for the ECU to relearn the new TPS.
04-12-2022, 05:22 PM | #5 | |
hawk dlx |
