Tore down the motor on my apollo 250rx and found that my exhaust valve was bent and began to make contact with the piston. Anyone have any links to valves and pistons that would fit? No info on them when I try to search the internet.
Verify the size of the bore. It should be 65.5 mm if an older engine. the newer engines will be 69mm. If 65.5 mm then any piston for a 2003-19 Honda Crf230f will fit including the Wiseco 11:1 piston. The same with the valves but verify your measurements to make sure.
https://www.ebay.com/itm/382670730611
#3 | |
I think they switch somewhere in mid 2020. If it has the oil site glass it should be the 223cc, if no site glass it will be a 229cc. My X22R is a 223cc and my Ghost is a 229cc.
#5 | |
So yours is the same as my X22R which would be 223cc. Just measure the bore to verify.
so I'm guessing there's no way to fit the 223 jug and piston to the 229 to get 254cc?
#8 | |
https://www.ebay.com/sch/i.html?_fro...e+kit&_sacat=0
apollo 250 rx, enduro |
