Old 04-27-2021, 09:23 PM   #1
Oltzer   Oltzer is offline
Pz30 Carb Repair Kit
So far the biggest dissatisfaction I’ve had with my new Brozz 250 is not being able to get it running quite right. I’m not completely ignorant of working on small engine carburetors either but have had frustration trying to find a proper sized tool to fit the mixture screw etc. I’ve read around and see many just swap the carb and others say this one is fine and tunable but wanted an alternate option then cutting the mixture screw and adding washers etc.
After looking around I found a pz30 repair kit on eBay from JetsPlus from the Uk and it just arrived. It’s basically a rebuild kit but looks to include better quality components with better sized jets (for my elevation) and also screws with proper fittings and adjustable needle etc. I still have to pull the carb back off the bike and pull it apart and validate everything matches up but right now I’m hopeful that the $15 brings this carb to the way it should have been.
File Type: jpeg 0E833BBC-63CE-453B-95B7-12074273C65F.jpeg (26.7 KB, 240 views)
File Type: jpeg BB2B16FA-961A-44BA-89B4-DC53876F8344.jpeg (27.1 KB, 225 views)
File Type: jpeg A763F132-5999-4774-902B-A5C92FA684EF.jpeg (30.3 KB, 243 views)
2020 Brozz 250
Old 04-28-2021, 04:24 PM   #2
JerseyTBR7   JerseyTBR7 is offline
It took me a long while to get my Minkuni dialed in right on my TBR7.
This is what I settled on at sea level and the amazon exhaust.
I settled on a 110 main, 30 pilot, and 1.5 turns out on the fuel air mixture screw. Take pics of the spring on the choke before you transfer it to the new carb so you know how it goes correctly.
Carb
Main jets
Fuel/Air
https://www.ebay.com/itm/111958216035
Pilots
https://www.ebay.com/itm/324295819136
Old 04-28-2021, 07:49 PM   #3
Thanks I’ll keep that in mind if I can’t get the pz30 working I’ll go with the Mikuni. I put the 112 main jet and 35 cold jet and new adjustable needle in the middle setting and it seems ok but I haven’t tried riding it yet with the changes. The new needle does have a different taper that I think would make it slightly richer at 1/4 throttle but so far seems ok.
File Type: jpeg CEB232EB-876C-433F-8D89-DA8F327A12D4.jpeg (52.1 KB, 237 views)
2020 Brozz 250
Old 04-29-2021, 11:13 AM   #4
I believe the PZ30 takes different pilot jets. If memory serves me correct, I believe you may want a 40 pilot in the PZ30 carb. It is a 30 in the Minkuni. But they are entirely different pilot jets types. The mains are the same types though between them.
brozz 250, carb upgrade, pz30
