Old 04-27-2021, 11:46 AM   #1
Biker_Andy   Biker_Andy is offline
Biker_Andy's Avatar
TT250 Manifold
The stock carb on the TT250 bolts directly onto the manifold. The PWK30 clone that I order from China has no such bolt holes to attach it. Is there a manifold I need to order to make this all work or did I order the wrong carb?
https://a.aliexpress.com/_mN3IZ1B
Thanks,
Electrician & Electronics Tech
2014 Honda CB500XA
2016 CSC TT250
1976 Honda CJ360T
2022 Honda Navi
Old 04-27-2021, 12:17 PM   #2
BgSkyRider   BgSkyRider is offline
You will need something like this
https://www.amazon.com/Motorcycle-Un...539521&sr=8-39
You will need to know the outside diameter of the carb engine side and the offset needed for the manifold adapter so it lines up with the air intake tube, unless you are using a Pod filter as well, if you use the pod filter you will have to make sure it does not hit the frame or have any other interference issues with fitment.
Old 04-27-2021, 12:23 PM   #3
Or this version:
https://www.amazon.com/PUCKY-Carbure...%2C254&sr=1-10
This will be the easier way, I used this on my DB-05 just needed to rejet it and adjust the float level but it's been working good.
Old 04-27-2021, 01:23 PM   #4
I think you are looking for a spigot manifold like this, but I have not done the installation and don't know the particulars on a TT 250 this one does work on a HAWK I believe but sometimes there are frame issues.
https://www.amazon.com/NIBBI-Perform...NsaWNrPXRydWU=
Old 04-27-2021, 02:46 PM   #5
Biker_Andy's Avatar
Usually stuff on Amazon.com won't ship to me in Canada and the selection on Amazon.ca is horrible in comparison. Aliexpress or eBay links would be preferred. The original one is bent with about a 45⁰ corner on it as well as a spot to hook up a small hose on the inside of the bend. I'll take a picture of it soon.
2014 Honda CB500XA
2016 CSC TT250
1976 Honda CJ360T
2022 Honda Navi
Old 04-28-2021, 02:04 PM   #6
Biker_Andy's Avatar
Seems I cannot take a picture under 0.2MB to be able to upload. Not sure when the files size limits got so tiny. I used to be able to upload pictures from my phone but I guess not anymore.
2014 Honda CB500XA
2016 CSC TT250
1976 Honda CJ360T
2022 Honda Navi
Old 04-28-2021, 07:30 PM   #7
XLsior   XLsior is online now
XLsior's Avatar
From the link you provided down the page there was this manifold shown.
https://www.aliexpress.com/item/32967821398.html
carb, carburetor, pwk, pwk30, tt250
