Old 04-19-2021, 02:47 PM   #1
MeatHammer   MeatHammer is offline
Df250rts X22R big bore kit
I am starting work on installing a big bore kit with cam, roller rockers and maybe some head work. I will update on progress and results. If anyone has any advice feel free to let me know.
Old 04-19-2021, 02:57 PM   #2
Download the Honda CRF230F Shop Manual. It will come in handy. https://www.google.com/url?q=https:/...i2fu68lr12Kmu9
Old 04-19-2021, 03:15 PM   #3
Also when removing the valve cover make sure you don't lose this little black rubber plug. Make sure you reinstall it too. Very easy to misplace or lose.
Old 04-20-2021, 12:54 AM   #4
Gutted. I had to pull the engine because I don’t have a garage at my house. The laundry room will be my workshop for this project. The wife loves it
File Type: jpeg 7BDBE088-6CD3-4E1B-B4FB-4DBB4A0BC993.jpeg (112.4 KB, 348 views)
Old 04-20-2021, 07:39 AM   #5
Must be tight spaces if you have to hang it from the ceiling.
Old 04-20-2021, 08:13 AM   #6
Bruces   Bruces is online now
I thought he was Australian !
Old 04-20-2021, 09:25 AM   #7
grumpyunk   grumpyunk is offline
grumpyunk's Avatar
Akshualllllyyy.... Hanging from the ceiling allows working while standing up rather than having to sit on the floor...
Wifey must be soooo happy you have a hobby. Annnddd stay home all the time instead of hanging with your buds... on the golf course, at the pool .. etc. Thing is, she wants access to the washer/dryer. On her terms.
tom
vertical and above ground - my daily goal
Old 04-20-2021, 11:06 AM   #8
I wish it was hanging from the ceiling. My knees are killing me today!
Can someone point me in the direction on how to post pictures the right way?
Old 04-20-2021, 11:14 AM   #9
Fixed it.
Old 04-21-2021, 02:21 AM   #10
So I am really confused right now. I pulled the head and I notice it has roller rockers. I look at the cylinder and was like “that looks bigger than the 67mm piston for the big bore kit. I start measuring and it seems that the bore is around 68mm on my stock cylinder. I lowered the piston down into the cylinder to see how the new one looks compared to the stock cylinder and sure as sh$& the 67mm drops in with room to spare. I measured the new cylinder and piston and they are 67mm. What on earth is going on?
Old 04-21-2021, 05:09 AM   #11
franque   franque is offline
I think you have the ZS169 FMM... They're slightly redesigned from the old Honda copies, and it sounds like maybe they're nicely specc'd from Dong Feng.
Old 04-21-2021, 07:39 AM   #12
Looks like you have the new 249cc engine. My stock piston was 65.5mm. Hmm, Maybe need to check what's on my Ghost.
Old 04-21-2021, 08:01 AM   #13
The thing is still stamped and labeled as 165fmm in two spots on the crank case. What does this mean for the aftermarket parts like the cam. Is there a performance piston for that size bore?
Old 04-21-2021, 08:07 AM   #14
I guess I'll find out when I remove my head. I have a head already ported and ready to install. I guess I better check before ordering a cam.
Old 04-21-2021, 08:14 AM   #15
I will post some pictures of the head. It looks like the same cam but I do think the head is a little different.
