Old 04-05-2021, 03:26 PM   #1
Nithious   Nithious is offline
Nithious's Avatar
Send a message via MSN to Nithious
vitacci pentora 250cc
Any one familiar with these ATV's and can help me out with some mods and part upgrades.
Old 04-05-2021, 03:41 PM   #2
There was a guy out riding one of those on the trails a couple weeks ago. If I remember right he said it was a clone of the Yamaha raptor 250.
2021 Tao Tbr7 - "Lucille"
2009 Q-link Legacy 250
Old 04-15-2021, 10:15 PM   #3
mobius   mobius is offline
Wink pentora 250cc
I have Pentora 250cc racing sport .
here is a list of mods I have done
PWK28 Nibbi carb
Nibbi manifold
Nibbi high-performance air filter
Everbright LED lamps P15D
Nilight ZH084 12" light bar
I am also getting a carb jet kit..20 pc. 10 slow 10 main
The PZ30 carb only allows setting your idle that's it. Bye bye POS30
This is only the start.
next is CDI, coil, chain and sprockets..
Got all off amazon.
I hope this helps you down the long mod road.
Oh . the carb size is 33mm by 44mm. 44mm is the air filter side
Also deleted the PAIR valve
Old 04-16-2021, 07:55 AM   #4
PWK28 Nibbi carb
Nibbi manifold
Got all off amazon.
The PZ30 is tunable. The idle mixture screw is covered with a plug that can be drilled out. Bowl screws can be slotted so you can remove the bowl to swap jets.
Old 04-17-2021, 02:04 AM   #5
pentora 250cc the beast awakens
Hello again. Update on PWK28 on 250cc V P SR
WOW......WOW.....WOW
Alli can say is HOLY Stuff...the change in torque on the get go is...HOLY ....
The change from the PZoSht30 to the Nibbi PWK28 is like last week to next year..Was not expecting how drastic the improvement was. I'm in S Texas.
out of the box; MJ 118 PiJ32 PJ28. I want to ride now but ...neighbors
The beast awakes
Do not buy the Nibbi manifold will not work.
iI had to chop the original intake.. about 2.5 " away from head side (do not worry about nipple, if you did a PAIR delete no prob) went and bought a 90 deg radiator hose and cut to fit.had to get away from rear shock assembly..air filter on a 45 so it fits .. The difference befoer/after hard to explain.....beyond shocked.
Old 04-17-2021, 10:10 PM   #6
Doh! Radiator hose.
Thought the radiator hose connection between manifold and carb would work, it does not. The hose did not fail but is very close. The cavitation between strokes caused it to weaken at the radius. I caught it in time. I will have to bend a 1" pipe at work..I'm going to use EMT I think it should work. The leftover radiator hose will be used to mate it all together. Still quick as s#!t. Have around 12 hours on the engine Got it up to 41mph.
Old 04-29-2021, 11:32 AM   #7
EvoLou   EvoLou is offline
Hi Mobius.
I just hit about 20hrs with my new pentora 250cc so I've been WOT'ing now. It's fast enough, but after reading your posts, I'm kinda itching to mod this quad.
What made you go with a PWK28? I looked it up and came up with this....
https://www.amazon.com/NIBBI-Racing-.../dp/B076CHRKNZ
Since the oem carb was 30mm, wouldn't this have been a better fit?
https://www.amazon.com/nibbi-Racing-...08H3DXAA1BCGZ9
Since you're using an aftermarket intake filter, do you still have the huge intake box? I would imagine no since there's not much room between the carb and the oem intake.
If/when time permits, can you posts pictures of your setup?
Thanks!
The beast awakes
Old 04-21-2021, 08:40 PM   #8
2020 Vitacci Pentora 250cc racing Sport ATV
Whatever, Sport first or Racing.
I replaced a STK. PZ30 carb, and upgraded to a PWK 28 Nibbi. OK......
When I "GOOSE" the throttle all is good, through to 3/4 throttle good, after that its like it bogs down. wwweeeeeethhhhoooo. got it? I believe I have my air/fuel right as well as the idle, bogs after 3/4 throttle
..Is this an up jet or down jet? Could it be the depth of the needle valve in the main jet? Variables , variablesthanks:
Old 04-21-2021, 10:01 PM   #9
Big Bird   Big Bird is offline
Big Bird's Avatar
Main jet, most likely need to go bigger.
2020 Boom Vader Gen 2
2019 CSC TT250
2021 Kayo Fox 70
Old 04-23-2021, 09:36 PM   #10
Stk NIbbi 28mm
Needle @ 3
MJ #118
PIL jet #32
PWR jet #28
ok I upped the main to #120
Helped up to around 3/4 THRT, then bog kinda like ahhhhhgggha to me its sounds like lean, like your running and no more balls. Where is the PWR jet.. Is it the jet within a jet?
Its cool I,ll be a pro by the time its said and done. More knowledge
Old 05-29-2021, 07:35 PM   #11
tyciti   tyciti is offline
hi guys im looking for any upgrades for this atv im not familiar with them at all so please keep in mind i dont know the lango for certain things and if u guys could link direct to part so can buy my self and put them in also looking for a pipe upgrade
Old 07-11-2021, 12:02 AM   #12
Alexander M   Alexander M is offline
Do any of you guys know what performance cdi to get for the Vitacci Pentora 250?
Old 08-03-2021, 07:24 PM   #13
AC racing CDI 6 pin (blue alloy finish) Prt#X0022JS6LGJ
Nibbi High-performance ignition coil prt# X0027XNUBF
Spark plug E3.36 (E3Sparkplugs.com)
Nibbi air filter 48mm KL-48-WT
hope this helps. i got my pentora 250 to 48mph. all parts from amazon.
Old 08-26-2021, 02:46 AM   #14
Razz Vitacci Pentora 250cc
Hello all,
I just added a slip-on silencer and what a difference it made. kemimoto Motorcycle Universal Exhaust Slip-on Silencers & Mufflers Compatible with Grom ATV Dirt Bike Street Bike Scooter Exhaust Pipe Diameter 38mm to
Manufacturer ‎kemimoto
Brand ‎Kemimoto
Item Weight ‎3.1 pounds
Product Dimensions ‎7.87 x 5.91 x 3.15 inches
Manufacturer Part Number ‎FFZH0132-02
I had been topping out at 47 mph for about 3 weeks before I changed out the stock silencer. On the first ride, I hit 50mph. I still had more, I now have the beginnings of the "Death Wobble". I have to solve the wobble, I have been researching steering dampers and the prices are from 100USD up to over 600USD. We are all aware of the fun of buying aftermarket parts and add-ons. I will update you again with information about which steering dampers can be installed on the V. Pentora
You will have to cut the original muffler off, get as close to the end as possible. Leave the 2 braces on the pipe, They will/can be used when installing the slip-on. I had it welded to the remaining exhaust pipe. It sounds great, a nice deep rumble while idling, and screams when at full throttle...The price was less than 50USD and came with all hardware needed.
I am going to try and get past 55mph. See Ya...
Old 11-26-2021, 07:59 AM   #15
Thumbs Up death wobble
Hey .
I got the death wobble fixed. The tie rod ends were blown out after less than 30 hours. Cheap Chinese parts. I replaced both inner and outer ends, and all four tires with Sun f tires. I am very impressed with the Sun f tires, they are holding up great.
I am hitting 51 mph with throttle left, I am going to "play" with the powerjet, and the air/fuel mix. I was told that I could not hit 55, so I made a wager that I could. He lost the first bet when he doubted I could hit 50, silly rabbit..
Will post again.
