04-03-2021, 02:59 PM | #1 |
Spark plug torque setting.
Any guidance on the torque setting for the spark plug? I’ve searched the forum and can’t find a spec for it. Manual says for a new plug turn 1/2 turn after seated. I’m much more used to torquing my plugs if anyone can give me the right setting. Thanks!!
04-03-2021, 07:19 PM | #2 |
Not to over-think it, as many will do this from "feel",....but the official NGK spec for 12mm plugs, is 11 to 13 ft-lbs......or about 144 in-lbs
<div>Steve 2006 Roketa DB-07A/RSX-200E 2008 Roketa 250 Scooter 2019 Brozz 250 |
04-04-2021, 03:14 AM | #3 |
Winner. Most spark plug torque specs into alloy heads is around 12ft-lbs.
04-06-2021, 06:19 AM | #4 |
Sounds good. Thanks!
09-17-2021, 02:16 PM | #5 |
Hot or cold cylinder head? Seems like it could make a difference.
04-03-2021, 07:24 PM | #6 |
I turn it until tight but not too tight. í ½í¸‰í ½í±Œ
2017 RPS Hawk. Mikuni carb, 117.5 main, 25 pilot. Foam filter. NGK plug. Upgraded exhaust. 17/45 sprockets. Digital speedo. Full LED all around. U5 handlebar spot lights. 1982 Yamaha XJ1100 Maxim |
09-17-2021, 02:38 PM | #7 |
My general rule of thumb for all threaded fasteners, if I do not have specs or it doesn't seem that important, is to turn it 1/8 turn (45 degrees) past snug. If that seems too loose, I will give it just a slight extra turn, maybe 1/16 or less. Turning 1/4 is too much. Important fasteners like head bolts I always torque to spec. I am extra careful with aluminum threads of course.
spark plug torque |
