03-07-2021, 08:41 PM | #1 |
Cam for a pentora 250
So I’ve been looking everywhere for a cam for my pentora 250 but cant seem to find anything on it.I’m trying to put a cam on it because I’m trying to squeeze out some extra horses out of it.The main reason I cant find anything because mine is a over head cam or ohc and most Chinese 250 are push rod.If anybody know anything please let me know where I can buy a cam for it
Thanks |
03-08-2021, 07:51 AM | #2 |
The Wiseco 11:1 piston for the Honda CRF230F will fit and so will cams for the Honda CRF230F.
Cams https://www.ebay.com/itm/UPGRADE-Cam...9/174322962671 https://www.ebay.com/itm/New-Hot-Cam....c101195.m1851 https://www.ebay.com/itm/BBR-Motorsp....c101195.m1851 Piston https://www.ebay.com/itm/Wiseco-4816...F/382670730611
03-08-2021, 04:25 PM | #3 |
Thanks so much I will order the cam and piston for it right away and how much power can I hope to gain by doing these mods
03-08-2021, 09:15 PM | #4 |
Good for 5 to 7 hp. Definitely made a huge difference on my X22R 250. Also porting the head and a 30mm smooth bore carb will add some hp.
03-09-2021, 01:36 PM | #5 |
Is there a stage 2 or stage 3 cam available or is it only a stage 1 available? and also where can I buy the smooth bore carb
03-09-2021, 01:56 PM | #6 |
Stages are just marketing terms, there are no fixed or set definitions... If you get a big cam, you might need stiffer valve springs, clearance the valve pockets in the piston, lightweight retainers, etc. Just to theoretically make it all work together physically, and then supporting mods like a different carb, exhaust, ported head and a high compression piston so that it will run well together.
If you're thinking in terms of stages, it might be best to start small and understand what you're doing first. |
03-09-2021, 01:59 PM | #7 | |
03-09-2021, 03:58 PM | #8 |
I understand what u mean and also will removing the egr valve help with horse power on nah
03-09-2021, 04:09 PM | #9 |
Nah, won't make any difference.
03-10-2021, 11:45 PM | #10 |
One question will a 420 sprocket fit a 520 chain or is it not possible?and thanks for all the help
250, atv, camshaft, power |
