Hawk 250 vs TBR7 front forks
Hello,
Does anyone know if the forks are the same on these two bikes? I have bent fork tubes on my 2015 hawk and taotao parts direct sales the set for both bikes with the hawk set being about 50 dollars more. They look the same but without technical specs I cannot tell if the length is the same. Any help is appreciated. |
They should be the same. I know they are the same as the brozz 250 (older models) and they are pretty cheap from brozz250.com .
I figured they would be the same and as far as the brozz, while doing research I always come across the USD forks. Brozz250 from 2014-2018 non blue eagle have standard forks. Thank you for the help TxTaoRider. Brozz250.com was the least expensive fork I have found. I'll update when I receive my forks to confirm incase anyone looks this up years from now.
#4 | |
Good luck. Where is dirt city texas?
The TBR7, Early Brozz (standard forks) and Hawk forks are all the same.
