02-27-2021, 02:48 PM | #1 |
Got my first hawk!
Picked it up used for 800 came with the mikuni carb and ~60 miles (speedo cable snapped). also is this the stock swingarm? Spotted a xr200 roller on craigslist. looking to see if i can swap some suspension parts and rims over so I can go on this little road trip we are planning this summer. For now I'm enjoying breaking in the motor in the snow. Last edited by L00N; 02-28-2021 at 02:18 AM. |
02-28-2021, 01:01 AM | #2 |
If you tried to post pictures, I don't think any of them showed up. Congrats on the Hawk.
As far as the swing arm, there is nothing wrong with the factory one as long as you aren't looking to do some jumping or rough whoops at high speed. Same goes for the rims. Keep the spokes tightened and check them on a regular basis and the wheels shouldn't be a problem. If you feel that you need to upgrade the rims, then any 36 hole Honda pattern rims will work with the Hawk. As far as the swing arm goes, make sure the pivot bushings and axle/bolt are well greased with a marine grade grease as well as the shoulders and bushing sleeves on the rear shock to prevent damage to the rubber swing arm bushings and binding. If you want to swap to an XR swing arm it will require welding tabs to the frame in order to accept the link system required for the Honda setup, or for somebody to weld aluminum tabs to the swing arm itself to accept a direct shock mount like the Hawk unit.
02-28-2021, 02:15 AM | #3 |
Hmm, seem to be having issues with images still.
Im planning on a little road trip this summer across 3 states mostly on back roads and some dirt roads. Any suggestions for sprocket sizes, there is a 50t on the rear and I have yet to confirm if the front is the 15t. I weight about 150 and would probably carry about 30-40 pounds of gear, and hoping to sustain 60-65 mph so I can hang with the dr350s. I've seen a lot of suggestions for a 17/45. |
03-01-2021, 08:14 PM | #4 | |
03-01-2021, 08:41 PM | #5 |
Thanks for the input. I think I may try 17/40. My usb/volt meter came today and I installed my hand guards yesterday. Maybe Ill have to place my sprocket order in now and I can try the new gearing this weekend.
06-20-2021, 07:17 PM | #6 | |
I'm not sure how long you've got to prepare, but I would honestly get some different rear sprocket sizes and see which pair does best. But, not sure if you've got time to do that. BE SAFE out there during your trip too, man! The cagers drive like buttholes. Good luck for the sprockets also; you'll get it in no time!
03-07-2021, 10:43 PM | #8 |
large image host Ebay digital speedometer with 13k. Decided to go that route because it was a little cheaper than the zanella one. Speedo, digital sensor, and USB charger was 60 shipped. I tried to reuse the old speedo bracket but one hole lined up and I butchered it trying to weld it to the first plate attempt. The speed sensor i ordered didnt fit and had to be dremelled down to size. I didnt realize that the hawks, tbr7s, etc have different style of ignition switches so this one is kind of squeezed in there with a little room for a usb charger. I've got the clock to stay on even after shutting the bike off by tapping into the red ignition wire. With a t tap https://shop.advanceautoparts.com/p/...5468/6300723-P Got the tachometer to work by making a "y" wire (one Male and two female bullet connectors). I tried to make all the wiring least invasive as possible and reversible. Any one know how to get the fuel gauge to work? I grounded fuel sensor(blue yellow) to stop it from flashing. Set the tire circumference to "lc-106" for the stock rim/tire combo and is GPS verified, there is a bit of lag between the garmin and the new speedo. Last edited by L00N; 03-08-2021 at 11:18 AM. |
03-20-2021, 04:06 PM | #9 |
Good deal!! I'm currently looking at them. Getting jiggity jazzed!
