Df250RTS
Hey all, new to Forum and 1st time rider. I just got my bike in a few weeks ago and breaking it in. My first mod i wanna do is the 36T rear sprocket and I'm having hell trying to figure out where to order a 428 36T 5bolt. And most sprocket websites don't list DongFang. I've tried PBI Sprockets but they never answer the phone. Just wondering if I'm missing something b/c i know its a clone bike but parts and upgrades seem hard to find. I've watched all the JerryHawk vids and they are very helpful. Thanks for any help or links with the sprocket info !!
Welcome aboard! The JTR242 sprocket is only sprocket available and it only comes in 50 and 53 tooth. You will have to order a custom aluminum sprocket from here. Just fill out the order form with the measurements. Bolt circle is 96mm, bolt holes size is 10.5mm, center circle is 64mm but if you remove the steel ring on the hub you can use a 58mm hole which would be a better fit. https://shop.pbisprockets.com/product.sc?productId=503
df250rts, sprocket |
