2020 Boom Vader Motor Mounts & 200 Mile Report
I bought my 2020 bd125-10 brand new a few months ago from venom motorsports. A lot of people were saying that the newer models of the vader have the upgraded motor mount bolts, but in my experience that is not true. They may be marked as a certain grade, but I believe its just cheap chinese metal still. I have 200 miles now on my 2020 vader and my engine bolts sheered right off. One sheered completely while riding, and the other was cross threaded so badly it was destroying the bolt, almost to the point of breaking (thank god I changed them both out). I recommend all vader owners get the two engine bolts swapped out asap for solid hardware. I went with grade 8 zinc plated bolts with nylon locking nuts. no more vibration, at any speeds! the vader runs solid now, check your engine mounts if you are experiencing a lot of vibrations!
(sheered motor mount) ![]() secondary question: what size chain should I upgrade to? the stock chain is awfully loose, no matter how much I tighten it. also, has anyone replaced the swingarm chain adjusters with the OEM style grom ones? curious if they would work better than the vader ones. my next plans for the bike: 1. oil cooler 2. tune the vm22 carb, its a huge performance upgrade from the restricted stock carb, and can get more power with better tuning (i need to order jets) 3. upgrade chain and sprockets 4. klx110 handlebars 5. dirt bike throttle tube 200 miles and counting, vader running strong! ![]() ![]() |
Glad to hear you got it sorted out. Whatever chain size you're currently running is probably fine, Chinese bikes tend to ship with cheap chains. It's probably either a 428 or a 428, either one should be sufficient for a stock motor.
Do you remember what sizes the two bolts were??
Too many bikes, so little time!! |
The factory bolts are M8 120mm. So if you go to standard 5/16 4.5-5" should work. I'm using some grade 12.9 from home depot and they seem to be holding up so far. If these fail I'm upgrading to ARP brand bolts.
2020 Boom Vader Gen 2 2019 CSC TT250 2021 Kayo Fox 70 |
I have a 2020 Vader BD125-15 and my bolts were marked 12.9 from the factory. I think I will replace them just as a precaution. I dropped my engine out of the frame anyway and China could mark them anything they want, but doesn't mean it is what is advertised. ARP bolts is a great idea. Thank you. I'm going to order up some 5/16 SAE to replace them.
I'm having good luck with my Niche brand non oring chain. The factory chain had to be adjusted almost every other ride. This one I had to adjust once shortly after install and not since. 428, 108 link.
#7 | ||
![]() Quote:
i was reading some info on exhausts and saw you posted this in another thread: Quote:
#8 | |
I just used the typical cheapo slip on that can be found on ebay for around $30. They have different lengths available. I'm using the shortest, its pretty loud with the db killer in it and really loud without the db killer. Since this pipe is a two piece you can twist it and it doesn't need heat and bending like a typical one piece grom exhaust. That said, if you bolt up the engine side first it will seem like it's not going to work. What you want to do is bolt up the header pipe to the engine last,bolt up the muffler side first, and then the header pipe goes on at a slight angle. The two gaskets crush to compensate for this slight angle. The header flange still bolts flat to the engine so you can torque it down and it doesn't effect the 'wedge' created by the double stacked gaskets. I recommend the copper gaskets(32mm). Disregard the orangness of the slip on, the flash makes it look that way. It's really a very dark brown after the heat weakened the black anno.
2020 Boom Vader Gen 2 2019 CSC TT250 2021 Kayo Fox 70 Last edited by Big Bird; 12-10-2020 at 10:34 PM. Reason: Add |
#10 | |
On the slip on, I'm running mine without the plug in the db killer. Had to grind the spot weld to pop it out. Just mock the whole thing up but leave the header flange loose against the head so you can move the pipe around. You can see where the bracket will need to meet the muffler clamp. If you want to keep the passenger foot pegs you will just need a long 6mm bolt to replace the pin. Another way to mount it is make a drop bracket and you bolt it with big washers to clamp to the ends of the rear sets. I think my way looks cleaner though.
#11 | |
got the exhaust hooked up. it bolted up easy, just like you said. fitment was perfect, just took a little bit of finessing with the header flange and the crush washers. right now i just hooked it up with zip ties from the slip on mount, i'll hit the hardware store and get an L-bracket for it soon. it sounds and runs so much better now! actually sounds like a bike haha ![]() ![]() i will need to rejet my vm22 now, its running very lean with the new higher flowing exhaust system. what jetting kit do you have in your vm22? thanks for the help bigbird ![]() ![]() ![]() ![]() ![]() |
Did you figure out the stock chain adjuster question? Seems like they would work if you also change the rear plate, since the grom screw is offset and the clone screw is in the middle.
My Vader came 'assembled' and it had the black hex head cap screws installed for engine bolts. They are marked 12.9, but I don't know it they are good bolts or if they will fail too. Last edited by GScott; 12-21-2020 at 05:53 AM. |
#13 | |
if the head of your engine bolt looks like this; ![]() change them immediately. they are no good. |
#14 | |
here are the part numbers for anyone reading this in the future: 40543-K26-900 - ADJUSTER, CHAIN 40546-K26-900 - CAP, SWINGARM END 90302-KBP-900 - NUT, SPECIAL (6MM) 94001-06200-0S - NUT, HEX. (6MM) ![]() |
#15 |
