Old 06-24-2020, 02:25 AM   #1
NzBrakelathes's Avatar
performance CDI are useless then
Only some advance from idle
Pretty useless in reality then, relates no doubt to other cheap china bikes
Old 06-26-2020, 10:31 AM   #2
Big talk yet incomplete - so no need to jet or adj pilot? How’s the spark gunna spark longer? How’s the CDI changing the curve if at all?
Old 06-27-2020, 01:41 PM   #3
krat   krat is offline
The last time I checked this guy's website was down and there was a long list of complaining people that had not had answers to their e-mails.
From what I have seen in the "legitimate tests" I have discovered there is no real measurable difference between the stock and HP versions of almost anything. Not a difference that can be noted without speed clocks that measure milliseconds.
Yelling 1,2,3 go and then trying to claim fractions of a second, or even a full second, difference in times over a course is bogus!
The money spent on trick parts would be better off invested in a good carb and proper jets.
To my mind a well tuned bike of any sort trumps a bunch of trick parts about any day of the week.
Old 06-30-2020, 09:43 AM   #4
Wild Dog   Wild Dog is offline
Because you will only gaining something when you use them with the right mods and most of them altogether.
You can put a new exhaust with a new header, but if you don't rejet you will most likely run lean.
Same goes for running a bigger carb with everything stock...
and the list goes on and on.
The problem is that some people think that with just a single mod that doesn't need to open the engine they will gain 10HP+!!!!
But yes the "Racing" CDI seems to the most useless one
