TBR7 exhaust weld and catalytic
I'm wondering how much of the weld can be ground down from inside of the exhaust pipe. While i have the exhaust off i thought i would also gut the catalytic. It looks like I have a small leak and thought i would just cut there. I have seen many people cut the catalytic in half. Is there a right or wrong way to do this?
2019 TBR7 2008 Baja Dirt Runner 125 2006 Honda XR100R |
I've done both my Hawk and X22R. Grind away.
Did you get noticable gains?
I'm sure there was but hard to say because i gutted the cat at the same time. Overall much better performance after the mod.
For some people who may not have a welder.
muffler shops are a awesome place. It's called a "Test Pipe" A test pipe is a section of pipe that replaces the catalytic converters. The muffler shop will cut your cat out and weld in a pipe to replace it. Not everyone has a welder or 150 bucks to buy a exhaust system. So this reply is simply another option. |
catalytic, exhaust, tbr7 |
