Old 04-14-2020, 09:02 PM   #1
Ratobin   Ratobin is offline
Taotao Hellcat turn signal flasher location?
Hi, I recently bought a used Hellcat 125. All of the turn signals will light up but not flash. I assume the relay /flasher is bad. Can anyone tell me where it's located? I searched google and also here and can not find the information. I thought it would have been a common question. Thanks in advance for any help.
Old 04-14-2020, 10:54 PM   #2
Ninjaguy23   Ninjaguy23 is offline
Ninjaguy23's Avatar
Not sure on the hellcat. My Vader’s was located behind the headlight fairing connected on the main wire harness. Should be the same for yours.
Cheers!
Old 04-14-2020, 11:18 PM   #3
Thanks! I'll take a look tomorrow.
Old 04-19-2020, 04:57 PM   #4
daytonacat   daytonacat is offline
If it is set up like my new 2020 Boom vader, remove the left side body panels and it is right in back of the spark control box. The little black about 1 inch by 1 inch looking box.
Carl
Old 04-20-2020, 06:01 PM   #5
Thanks Carl. I found it. It is on the right side under the side panel. Several inches above and behind the starter motor. I'll post some pictures when I can just in case someone else is looking for the same information.
Old 04-26-2020, 01:10 PM   #6
Here's a couple pictures. Maybe they will help someone looking for the same thing.
