Just bought 2020 tbr7
Been reading many posts here before joining. I just bought a 2020 tbr7 from txpowersports.com. It finally came yesterday after waiting a month. Crate was beat up and there is some scuffs on the plastics. Hopefully putting her together tomorrow. I was wondering if it's okay to mess with the carb and exhaust now or wait until it's broke in? Also, I had no problems registering it in Blair County, PA.
Lots of people mod them right out of the box. Shouldn't be an issue. Don;t forget to check the valves and change the oil before you even start it.
Sounds good and thanks for the reply. My 5 year old son and I just put together his 50cc syx moto dirt bike. Now he's ready to help me with mine.
Tx made it easy. Front wheel and fender, handlebars, headlight, hand guards, and battery were all I needed to put together. I'm going to change oil tomorrow and try out the first ride. I have an accelerator pump carburetor coming for it. I put one on a 125 atv and it worked awesome.
Awesome. I'm eyeing the TBR7. Let us know what you think once it's all together and you've had a ride or two.
Digital speedo is nice on these as well.
Adjusted the valves, rejetted the carb and took it for a short ride. Runs awesome. Still some carb tuning to do but I'm going to wait for the pumper carb. Digital cluster along with exhaust are in my amazon cart, waiting on funds. Has anyone installed handlebar risers? I feel like I'm leaning forward too much.
#9 | |
When i got my 2019 TBR7 my bike was soft in the front and felt like it was a little low in front when i sat on it. So i found the links on this forum and got to work. With these bikes (hawk included ) the front springs are soft and each bike comes with a small spacer on top of each spring , it seems some bikes have about 10mm and others about 15mm but even on the same type of bike they have different size spacers? So its a good time to change the oil (of unknown quality and amount ) in the front suspension anyway . In my case i put in 15w but now i have a baseline to go thicker or thinner . Again in my case i did a piece of white pvc pipe about 50mm long in each strut which is a little more than others had done but it works fine for me. I did put pictures on the forum and others have covered this too so you should find a lot of info . One thing that comes up is to not loosen the allen head bolt on the bottom of the struts to drain the oil. That bolt holds the damping rods in and can be a pain if it strips out. You are better off to remove each strut (remove the front wheel ) and take each strut and loosen the top cap and turn it upside down to remove the stock spacer and spring and the oil ( measure the amount of oil that comes out as a reference ) . some have found different amounts in each strut. Cut a piece of 7/8 pvc pipe (length more than you have stock to 50mm or more, at 50mm it is quite hard to get the cap back on with the pre load ) Add your quality 5w to whatever weight you chose and the same amount of oil in each ( i don't remember the correct amount? ). This will stiffen up and lift the front of the bike . If this still does not feel like enough then get bar risers or higher bars. Another thing to consider , while you have the front apart is to grease the steering head bearings as some bikes have plenty grease and others little to non. Hope this helps. |
#10 | |
~ Don't poke the bear ~ M.M.I. Dean's List graduate class of '95 and Specialty welder 2020 Ice Bear Terifecta 150cc Trike 2011 Honda Foreman 500ES 4x4 2001 Polaris Scrambler 400 |
#11 | |
I'll do that work to the front forks for sure. It's getting cold here in PA so I won't be riding it too much. Probably just going to upgrade everything and tune it in.
Is a url link the only way to post pics?
#14 |
Where do I find your cluster?
#15 |
Nevermind, I found it. Not to be rude or anything, but why is yours better? I would just like to know before I buy one.
