Old 10-14-2019, 12:03 PM   #1
alex_in_az   alex_in_az is offline
K&N filter part no
Is HA-0502 for the TBR7 and bikes with the flat "lawn mower" style filter airbox
2020 Tao TBR7
9.3:1 PnP head
CRF230F exhaust
4 degree advance key
290 degree cam
Nibbi PE30 and cone filter
Front fork brace
Old 10-14-2019, 12:20 PM   #2
AresROC   AresROC is offline
AresROC's Avatar
For the price I would just get a cheap pod filter. I ride primarily in the dirt/desert.
For my GSXR I have the K&N filter. Pod filter easier to take off and clean too. (my next project) XD
Edit: That looks exactly like my Bashan BSR filter, size 135mm x 115mm
BaShan BSR 250 DB-41H 2018 Red BS250GY-18D
JFG Racing Exhaust . Adjustable Shock 320mm . Brozz Digital Gauge . Renthal Fat Bar . 428 17x46 Sprocket . Fender Eliminator . Wheel Truing . Fuel Tank Repair .
Keihin PZ30 Main-115 Pilot-38 Needle-1Washer Fuel Mixture-1/2
BSR Chronicles - "Project leads to more projects!"
Yamaha WR250R
Suzuki GSX-R 600
Old 10-14-2019, 12:47 PM   #3
I considered that at 1st, but my leg would have been touching the pod for a good sized one and this looked a cleaner installation.
2020 Tao TBR7
9.3:1 PnP head
CRF230F exhaust
290 degree cam
Front fork brace
Old 10-14-2019, 01:03 PM   #4
Red Hawk   Red Hawk is offline
Red Hawk's Avatar
I had one of those. It was horrible excuse of a filter. They are used dry no oil ever, the face is dyed red just to confuse you. They don’t fit well too short so you’ll need a bent wire square shaped spacer to fill the gap. Way to restrictive on flow you’ll see. All the Amazon reviews aren’t great I thought my experience would be better.
I’d like to cnc a frame from plastic and glue in a UNI foam filter. I have the materials on had just no open time on the Machine. Winter project.
2018 Hawk P&P Decked .040 off the head. 17/43 D.I.D. 428, NGK Iridium plug, DeCat, Wrapped pipe, Custom S.S. Muffler core, Nibbi PE30 115/35, L.E.D. Lights, Digital Cluster, USB port, Cutting Bord skid plate, Oil cooler w/ custom CRF oil filter inline, 5Wt fork oil, Rear Shock, CNC Back Rack, 30mm FAT bars, Bark Busters, ProGrips, Adjustable levers, Shinko 700’s lots of Loctite!
Old 10-18-2019, 08:09 PM   #5
I got it dialled in today, had to up the main from 110 to 115. This tells me its flowing better than the stock filter. This was a perfect fit into my airbox, maybe they changed the design of the air box?
2020 Tao TBR7
9.3:1 PnP head
CRF230F exhaust
290 degree cam
Front fork brace
Old 10-17-2019, 10:27 AM   #6
everready   everready is offline
IMHO, K&N is overpriced junk. Just get a washable foam filter.
Old 10-18-2019, 09:47 PM   #7
Red Hawk's Avatar
My mods as follows 120 main 27.5 pilot PZ30 paper filter stock exhaust w/ no cat. Muffler tip is gutted out. Ported head decked .040 for compression. Air box lid is opened up. It’s actually a little lean when it’s real hot out.
Old 10-21-2019, 08:36 AM   #8
Cravin01   Cravin01 is offline
Cravin01's Avatar
This is exactly what I plan on doing to my bike, I've been putting it off due to work. I like the stock look with added water protection. I think the K&N for mine will be like $26 and I may have to do light modding to get a good seal.
Looks great!
Visit me on YouTube at "Project Next"!
https://www.youtube.com/channel/UC6KTCi2GVbfRDv-2XCqHhsg?view_as=subscriber
2017 Bashan Storm
Keihen PZ30 Pumper Carb,115 main jet,35 pilot jet, gutted factory exhaust, Sambo Digital Speedometer,LED blinkers, H4 headlight,D.I.D X-ring chain 428,17/42 sprockets,UNI cone filter.
Old 11-23-2019, 02:31 PM   #9
ikeus685   ikeus685 is offline
Send a message via Yahoo to ikeus685
K & N or ???
Looks great!
I plan to do a partial gut out of the stock Vader and have been finding all the
K & N's in the $45.00 plus range. I must be looking wrong. HELP!
Old 11-23-2019, 02:41 PM   #10
Red Hawk's Avatar
I have a slightly used K&N from my Hawk I’d be willing to lose, need the room. It’s current use and better then OEM use is to hold down my 3 tier pallet rack.
Old 10-21-2019, 11:39 AM   #11
If its lean with it really hot out, it should be even leaner when it gets cooler outside.
Old 10-21-2019, 01:38 PM   #12
OneLeggedRider's Avatar
Dan I think you should start a thread and call it "Basics of carburetor principles, tuning, and theory 101" and possibly Jerry can make it a sticky, as the knowledge is clearly needed here.
~ Don't poke the bear ~
M.M.I. Dean's List graduate class of '95 and Specialty welder
2020 Ice Bear Terifecta 150cc Trike
2011 Honda Foreman 500ES 4x4
2001 Polaris Scrambler 400
