Chain Question
I did a search but don’t completely understand the chain options. I would like to keep my current stock sprockets 17/46 but want to purchase a good quality chain for them. I don’t know what “520” or “428” means. Can someone recommend a good quality chain that wont break the bank for my stock sprockets? The chain that came with the bike stretches like a rubber band and I am concerned about its quality. Thanks.
2019 Bashan Brozz 250 2019 Honda Africa Twin CRF1000L |
A quick way to check is to measure pin to pin (pitch) A 428 chain is 1/2" and a 520 is 5/8".
This is the one I bought for my Brozz, but haven't put it on yet.
https://rover.ebay.com/rover/0/0/0?m...2F322043802661 |
#5 | |
JT Sprockets brand is your go to for budget Made In Japan chains and cogs. I'm running their heavy duty dirt bike chain $15 and have a couple different cogs from them as well. I put 5,000 miles on the Bashan stock chain and have 6,000 on the JT. About every 2-3 weeks the stock chain had to be re-tightened and the Japanese version I've adjust only 3 times just to be safe after binding it up whilst riding like a turkey.
Bashan Storm: Ebay steel exhaust wrapped, folding shift lever, seat mod, vm26 carb, air pod, dual led scrambler headlamps, windshield mod, led brake/tail light, secondary led brake light (swingarm), Ebay 295mm rear shock, back up CDI (racing unknown), oil cooler, digital gauge cluster, |
I suggest when changing it’s better value to go 520
https://rover.ebay.com/rover/0/0/0?m...2F222121202245 |
but then you have to change sprockets
2018 Hawk - Nibbi PE30, Nibbi Intake, UNI Filter, Ebay Exhaust, NGK 4929 (non-Iridium), 428 D.I.D. X-Ring, 15/40 Sprockets, Walmart AGM Battery, IMS Shifter, Full LED Lighting, Digital Cluster, CSC Swingarm Pin, Modified Chain Adjusters, Upgraded Wheel Bearings ** MPH Cruise, ** MPG |
This is the chain I'm using. Just cut to length. https://rover.ebay.com/rover/0/0/0?m...2F321318221273
#11 | |
Very well. I have about 2500 miles on it and never had to adjust it except for when I had replaced the rear tire.
