05-15-2019, 06:51 AM | #1 |
Magician 250 parts
I'm new to China bikes, and really bikes in general. I recently bought a magician as my first bike. Unfortunately, I had a crash a decently high speed and the front end was heavily damaged. My question is, what size are the front rim and brake disc? They were too heavily to take accurate measurements from. Also new forks will most likely be needed. Any information on where to find parts or at least sizes so I can track them down on my own would be greatly appreciated.
05-15-2019, 08:54 AM | #2 |
The best bet for original replacement parts would be to contact a distributor, like the one you purchased through, and order the parts from them.
As far as the front rim. It's 19 inches in diameter. I don't know the width off hand, but seeing as the front tire is a 100mm width, it is likely a 1.85" at a minimum. As far as the rotor goes, dimensionally I wont be of any use. Hopefully another Magician owner can chime in and help out.
05-16-2019, 04:49 AM | #4 | |
Anyways that front rotor is ~¥30.00 to most (Remote 3 autonomous regions need pay extras...) mainland China address.
05-16-2019, 09:37 AM | #5 |
There’s also a bigger front brake upgrade to 240mm with a new caliper etc
Costs a bit more but won’t be crazy |
05-15-2019, 08:23 PM | #6 |
Sounds like the bike took the brunt of the pain.....hoping you are OK.
05-15-2019, 11:45 PM | #7 |
I measured the front Magician rotor. 9" diameter and thickness of .142". The available braking contact surface depth from edge to center is 1 3/8 ". That is the total available across from the edge of the rotor to center bolts and not the contact area of the pads which is smaller.
05-16-2019, 12:04 AM | #8 |
Correction to that rotor diameter more like 8.5 " or little more as measuring around the center bolt.
05-16-2019, 02:06 AM | #9 | |
This looks exactly like the Magician front rotor: $25 with free shipping. https://www.aliexpress.com/item/Moto...d-7731ebe37925
05-16-2019, 11:54 AM | #10 |
I'm fine. Miraculously, just a light scrape on the shoulder. Just pretty bummed about the bike. Not even 150 miles on it yet.
05-16-2019, 03:42 AM | #11 |
The rim will be marked
Bash the rotor flat and measure it The rotor is special to the magician and I can supply that at least A rim you might be better off getting that fixed in the USA maybe? I’m in Chengdu China and I don’t have cheap shipping options only EMS for bulky stuff or epacket for small items See attached photo each disc is only $25 includes shipping Payment via PayPal as currently I can’t add more to my eBay listings sadly |
05-16-2019, 02:37 PM | #12 |
Rim and brake disc successfully tracked down. Thanks for the help. Now I just need to source some forks.
05-16-2019, 03:21 PM | #13 |
The forks themselves are easy enough to track down from China, but the question will be what the final cost is. https://www.yoycart.com/Product/594002291516/
They might be 80 bucks there, but then you have to pay to ship them from China, and given the size and weight of the package you could be looking at a couple hundred bucks to ship them over. Like I said before, call whomever you bought the bike through, they can usually order parts for you. Just be prepared to spend at least $200.
05-16-2019, 08:12 PM | #14 |
My local post office only does ePacket and EMS - Here's how the calculation go.
http://shipping.ems.com.cn/product/f...ail?sid=500024 How about converting to USD? Mind you they are rather expensive and you would need the complete front end etc. Check up on parts in the USA first at therps something like that or just call these guys - https://www.txpowersports.com/pit_bi...bike_s/287.htm |
05-18-2019, 10:00 PM | #15 |
My first casualty on my Magician was the spring loaded pivoting rear brake pedal vibrated off. Does anyone know of a part that upgrades the factory piece? Or just order s other stock style?
From a CRF250L to a Magician?! |
