04-05-2019, 08:58 PM | #1 |
Taotao Rhino 250 valve lash specs
Title says it all what is the spec for valve lash on the rhino this is a 2013 rhino if that matters or not, thanks in advance
04-06-2019, 07:23 AM | #2 |
I believe most people set them at .003" and .004". I set .002" for both which is what the Lifan CG manual says.
04-06-2019, 08:50 PM | #3 |
thanks
10-26-2020, 12:32 PM | #4 |
Hi there ,
I’m still searching for a taotaorhino 250 service manual. Does anybody know where I can get my hands on one, or another model that uses the same engine? I have replaced The clutch but I’m getting no resistance when I manually try to move lever on side of crank case. Is seems like I’ve forgotten to replace a spacer to bring out the clutch plates to meet the pin that engages the clutch. Has anyone run into this problem? |
10-26-2020, 07:50 PM | #5 | |
10-26-2020, 12:34 PM | #6 |
Or have access to the service manual so I can retrace my steps????
Thank you , John. |
10-26-2020, 01:46 PM | #7 |
Do a search for a factory service manual for a Honda CG125.
10-26-2020, 02:02 PM | #8 |
storm-english-62ktjam5.pdf
This is the one I downloaded several years ago. If there is a place to upload it to this site I'll be glad to do it. It's about 8.5 megs. |
10-26-2020, 05:14 PM | #9 |
https://josemaco.files.wordpress.com...h-62ktjam5.pdf
When I searched for the PDF name it actually pointed to a thread here at China Riders, with the link. That manual states 0.003 +/- 0.001 for exhaust and intake. |
