Old 04-02-2019, 09:33 PM   #1
neat ideas on head porting
stumbled upon this nad i think may be of interest to some here. five or six parts to it. http://mototuneusa.com/power_news_--_think_fast.ht
may or may not relate to our 14 hp monsters but it might.
2016 hawk
kaw h1 400 tripple
13' long chopper in progress
2009 johnny pag bar hog
Old 04-02-2019, 10:12 PM   #2
Its_not_a_honda   Its_not_a_honda is offline
Link does not work
2020 Kawasaki KLX300R, 2018 Yamaha TW200
If you want more of something, tax it less. If you want less of something, tax it more.
Old 04-03-2019, 12:09 AM   #3
Mallen   Mallen is offline
First go to the base url: http://mototuneusa.com/
Then scroll down to the bottom of the page, and on the lower left corner look for: Power News Preview
No idea why it forces you to do it manually.
Old 04-03-2019, 12:22 AM   #4
this was copy and paste from part 2 http://mototuneusa.com/power_news_--_homework.htm
maybe its the dashes messing it up
2016 hawk
kaw h1 400 tripple
Old 04-03-2019, 12:24 AM   #5
this is the page for all links http://mototuneusa.com/thanx.htm
2016 hawk
kaw h1 400 tripple
Old 04-03-2019, 03:15 PM   #6
paulsstag   paulsstag is offline
i'm going to say that its possible in the right circumstances. Its possible the ports have been made bigger and bigger over the years to increase the power of the engines ? Anybody here on the site remember the Ford Cleveland V8?
Basically the ports( 4 venturi heads)(4V ) were hugh by factory standards and a lot of horsepower could be had at very high rpms . The 2 venturi heads (2V)were too restrictive by the same measures. Because the 351C engines were used in mustangs ( and others ) the factory did not want them revving to 7000 plus rpm where the ports started to work well. You could a few years ago buy a port plate that pretty much covered up about a third of the port ( looked similar to the jb welded port). Much better torque and horsepower was the result.
The Australians Built a new cyl head (called a 3V )that took the best properties of the 2 heads .
Some one needs to try it on the 229 and let us know.
Old 04-03-2019, 07:51 PM   #7
ben2go   ben2go is offline
I had a big block 351 Cleveland in a 73 Ford long bed Ranger custom cab. It was backed by a C6 auto transmission and a 9-inch positive traction rear axle.
Old 04-03-2019, 12:11 PM   #8
Azhule   Azhule is offline
Basically "Clay and shape for a Smaller/Velocity Stacked Intake Ports to gain 7% more power"
There is someone with a KLR650 that claims their "Big Bore/fully built engine" is making close to 90 horsepower (at the wheel) with the help of "Small/Velocity Stack Intake Porting"... the power/numbers I feel are a bit suspect due to the Dyno they are using... seen too many "extremely happy customers" when they get numbers back on their (stock) bikes/cars...
Old 04-04-2019, 01:59 AM   #9
Taking the already well designed ports that the manufacturer spent thousands of hours designing, modeling, simulating, and testing to get the right balance of intake velocity, flow, and swirl, hogging them out way too big, and then adding a sharp turn on the short side radius right before the valve is about as bad of an idea as I have ever seen.
I get what they are trying to do, but they have nothing to back up their claim with. 7% more power? That's vague. 7% more power where? A before and after dyno plot of multiple runs would be far more convincing.
They likely picked up a little more power in the lower RPM range due to that higher velocity, but I would almost bet there is a loss in high RPM power due to a decrease in total mass flow. Decreasing the cross section right at the radius, right before the intake valve seat will do exactly that, decrease mass flow (and likely increase turbulence).
In fact, if you want to watch a good counter video to this whole idea, I welcome you to watch one of my favorite channels who does a great response to this whole methodology.
