03-27-2019, 12:23 AM | #1 |
2019 Hellcat from familygokarts fails 2nd inspection.
I took the Hellcat for another inspection. It failed. I was told the bearings in the headset were problematic. With the front wheel off the ground you could feel some resistance when turning the bars. I said to the guy, I don't ride with the front wheel off the ground.
This shop that does the inspections is kind of boutique. Kind of high end and backhandedly talked shit about my bike. I get it. It is what it is. But I thought he was being too douchey at this point. I left without paying and went to a Harley oriented shop that gave me a sticker. I'm not sure why I posted this. Maybe I just wanted some feedback. Sure the headset bearings may be flat in some areas but shops charging a grand over MSRP should be closed on site. |
03-27-2019, 07:07 AM | #2 |
It's their job to inspect the bike, not give their opinion of it , or on it. Sounds like they don't need to be doing state inspections if that is how they operate .That said , I had to disassemble the triple tree on my Vader and regrease the steering stem bearings when i assembled mine, there was next to no grease at all in there ( if you can even call the stuff China put in there grease ) and the long ocean trip in a shipping container had let the salt air cause some surface rust and that , along with the very small amount of grease made it feel " notchy ".I cleaned out what i could, packed it with good grease and it was perfect , super smooth no more catching or notchiness.
At some point i think i'm actually going to go back and drill / tap / add a zerk fitting to the steering neck ,there's plenty of room to do so . Anyways I'm glad you got it stickered in the end and can put some miles on her without having to worry about the Cops lol.
03-27-2019, 07:37 AM | #3 |
Glad to see you got it stickered. A place like that would get any kind of business from me.
RedCrowRiders brings up a good point about greasing up the head set bearing. I installed a grease zerk in the steering column and pumped it full of grease and did the same for the swing arm.
03-28-2019, 04:54 PM | #4 |
JerryHawk250 did that on his Hawk. The holes were already there. He plugged the lower one and tapped the other one for a grease fitting. I did the same and it works great!
Dan-O -2018 Tao Tao HellCat - DOA -2016 Hawk 250 - Kitty Hawk - eBay exhaust, Mikuni carb(120 main/30 Pilot), airbox mod with K&N filter, digital cluster, total LEDs, 17/45 sprockets, RK chain, Shinko 244 tires, trunk, aftermarket levers, burrito tube, skid plate, Sargent Cycle Seat... -2003 HD Sportster 100th Anniversary -1999 Buell X-1 Lightning - Race kit, Buell Seat |
03-28-2019, 06:50 PM | #5 |
That sounds a little advanced for me. I barely made it through the fender delete.
03-28-2019, 07:56 PM | #6 |
My Hellcat turns smooth but I want to upgrade the bearings because I'm sure they are not the best quality. I use mine primarly for trail riding so I want to avoid any potential issues. I'm not sure if Grom bearings will fit, does anyone know?
03-28-2019, 09:16 PM | #7 |
Checking in...
Hey scoot newb, just a quick note to let you know I posted over on kirbo7106's thread about his damaged Hellcat in case you don't notice it.
Basically, just wanted to let you know I'm around in case I can be of any assistance. FamilyGoKarts doesn't get mentioned often on here, but when we do I try to pop in and say Hi and help where I can. Brad
http://www.familygokarts.com |
03-27-2019, 10:22 AM | #8 |
I do have to admit, with all the BS we put up with here in CA, inspections aren't required. Once a bike is CARB approved, done deal.
I'm glad the HD-type shop took care of you. They're usually pretty laid back. The one I frequented used to give you DOT stickers for the back of your brain buckets.
03-27-2019, 10:44 AM | #9 |
I'm with JHawk on that one,...I wouldn't give them any business. f them. Glad you got it legal. My vader has started feeling a tiny sticky in the steering. I'm guessing I need to do that next lol
BD125-15 |
03-27-2019, 04:45 PM | #10 |
Thanks all.
Imm'a try to add grease this weekend. Last edited by scoot newb; 03-28-2019 at 12:09 AM. |
03-28-2019, 09:19 PM | #11 |
I saw it and replied. I think it would be better if you responded to us directly instead of trying to do damage control on a public forum. I am 2 weeks in and familygokarts hasn't taken any action to address the damaged merchandise or attempt to get the bike up to DOT or State standards. Instead I get a reply from Jeff every few days asking me to reiterate the problems with the bike and making excuses. Replacement parts haven't been sent and if I didn't spend money out of pocket, it wouldn't even be running.
03-28-2019, 09:23 PM | #12 |
I will check into it for you. I don't handle support issues, but I'm happy to escalate your ticket.
Please understand, I'm just trying to help. Being uncooperative just gums up the works.
03-28-2019, 09:28 PM | #13 |
I hope you're not implying I'm being uncooperative. I've taken many photos and have gone over in detail each problem more than once with Jeff. I don't understand why my (and other members problems) weren't escalated in the first place. If you can help great, but all I see is damage control at this point.
03-29-2019, 09:50 AM | #14 |
Not sure where you're located, but I took mine into a car shop. For motorcycles, they just check to see if you have headlight, tail light, etc.
$7 for the inspection and I'm on my way. May have convinced a couple guys there to pick up an Ice Bear Fuerza. lol. You could always upgrade the triple tree. Lots of chinese companies have replacements that include front forks as well. |
06-14-2020, 07:20 PM | #15 | |
