03-09-2019, 11:43 PM | #1 |
Need Tips on Apollo Carb Removal
Hey everyone:
I finally had some free time to try to install the new carb. Got the new jets and the installed those in the new carb. I was able to remove the two nuts holding the carb to the head. I loosened the retainer ring that mounts the air filter assembly to the other side of the carb and even got as far as pushing black air filter assembly off from the back of the carb. However, I cannot seem to get the carb out far enough where I can actually remove it. It's a very tight fit. The air filter assembly is very different than what's on the Hawk. I thought about removing the whole air filter box from the bike, but I couldn't quite seem to see how it mounts to the frame. The other idea I had was removing the intake manifold part that actually bolts to the cylinder head and then the carb mounts to that. My only hesitation with that approach is that I didn't know if there was a gasket on the other side of that intake manifold part that I'd have to replace once I removed the intake manifold. Is there a trick to getting this carb out? As I said, it's an extremely tight fit. I was able to push and pull the large black air filter assembly "hose" a bit; it's pretty "firm" though. I just can not seem to get it it out of the way enough to get the carb off of those two bolts coming from the head. And, from the videos I've seen on removing the carb, turning the top cap of the carb (the part where the throttle cable goes) looks pretty easy. The guys turning that counter clockwise seem to turn it rather freely. Mine is super tight. I tried to turn it with a crescent wrench and ended my marring that cap. Any help is greatly appreciated. |
03-10-2019, 12:26 AM | #2 | ||
03-10-2019, 07:16 AM | #3 |
Thanks Douglass for the help. Removing the intake manifold should do the trick. And, you’re right about the copper “plug” or screw. I guess the manufacturer really didn’t want anyone missing with the carb!
03-10-2019, 08:03 AM | #4 |
PM sent
03-10-2019, 08:34 AM | #5 |
Thanks for the help! After reading through the carb thread you gave me a link for, I'm wishing I bought a pumper carb now! Oh, well, I can always upgrade that later.
Another question. The new carb says 100 for the main jet and 40 for the pilot jet. I am trying to decide between the 115 and the 120 for the main. As for the 40 on the pilot jet, it looks like I ordered the wrong pilot jet kit. The pilot jets are much larger in diameter than the one that is in the new carb; so they don't come close to being able to screw in. The stock pilot diameter is much more skinny. I'm still going to go ahead and button up the bike today to get it started for the first time (with the stock pilot jet since I don't have any others that fit). But can anyone help with a pilot jet kit in case it needs to be tweaked a little? |
03-10-2019, 08:40 AM | #6 |
I can confirm that the new bike does have this "cassette" style air filter (as they call in on the Orion website). These "cassettes" are positioned like in a series, one spaced about 2 inches from the other. I can't imagine it can breathe all that well. I'm thinking an air filter upgrade is needed in the future.
I've never seen that Orion website before, but found it through it's_not_a_honda's" previous thread. Nice to know that there if I need a part. |
