12-09-2018, 07:23 PM | #1 |
Tips for winterizing?
Time to put the bike away. Anybody have suggestions for winterizing motorcycle?
12-09-2018, 09:03 PM | #3 |
I usually "Fog" the engine to prevent rust before winter storage and also add some kind of fuel stabilizer (Sta-bil Marine and Star Tron are easy to find in the States and work as advertised).
To "Fog" the engine all I do is spray some kind of "upper cylinder cleaner/lube" into the engine while it is running... spray until the engine "bogs" a little then I turn the bike off... Sta-Bil and SeaFoam also make a "Engine Fog" spray if you don't already have a dedicated "UCL"... You can also drain the fuel bowl on the carb to get any fuel out so it doesn't slowly evaporate into goo and clog the jets over the winter break
12-09-2018, 10:35 PM | #4 |
If at all possible move the bike inside, like heated grauge would be best.
Next mouse proof the Airbox and everything else is already mentioned. I'd keep the tank topped with non-Ethanol laced fuel with a good dose of fuel stable. An empty tank is an open path to condensation. Aircraft are always stored full. Doesn't hurt to run it for a few minutes a monthly.
12-10-2018, 05:36 AM | #5 |
Everything they said especially topping off the tank AND draining the carb bowl (small screw on the nipple on the bottom of the bowl).
I always drain the oil and put in clean oil before storing a bike for a decent length of time. It helps prevent swarf (metallic particulate) and sludge from settling to the bottom of the engine case. Another thing I tend to do is pump the tires up to maximum pressure, and if you can, put it up on a stand to take the weight of the bike off the tires. This can help to prevent possible flat spots on the tires. Oh, and a trickle charger is a good idea.
12-11-2018, 01:06 AM | #7 | |
Good to see you back. Seems like you have been gone a while. Thanks for the input! |
