Hawk took kit
Hello!
My new (to me) Hawk is missing the OEM tool kit, and i'm putting together a on-bike kit. What do y'all carry to do on the road maintenance and can someone list what is in the OEM kit? Thanks for helping! |
The tool kit that comes on with the Hawk is just a few cheap open end wrench, sparkplug socket and junk screwdriver. If you broke down on side of the road the tool kit wouldn't have all the tools you would need. Best thing to do is go buy the open end wrenches you need for the bolts that you need or an adjustable wrench, a multi tip screw driver and a 1/4" ratchet with a few metric sockets. Make sure you have something big enough that you can remove the axle bolt in case you have a flat or need to adjust or reinstall the chain if it comes off. And of course tire spoons, patch kit and a small bicycle pump.
ZIP ties, electrical tape, spare bulbs, rags, small bottle of hand cleaner, couple of master links and few links of chain, small can of chain lube, small piece of electrical wire and crimp connectors.
#3 | |
That sounds like a good start, can you suggest what size wrenches/allen/torx I should get? |
8mm,10mm,12mm,13mm,14mm , I don't remember the axle bolt size. I use an adjustable wrench for that. Put a few nuts and bolts in case one comes off while riding. With a new bike there was lots of extra nuts and bolts that came with the bike so I threw a few in a zip lock bag and put them in my burrito tube.
#5 | |
If you want to keep it as simple and streamlined as possible, an 8mm, 10mm, and spark plug sockets with ratchet and a medium extension, an 8mm and 10mm combination wrench, paired with at least a no. 1 or no. 2 JIS screw driver and a pair of adjustable wrenches will give you the ability to work on about 90% of the bike. Take it a step further with a "trail" tire iron kit with a tube patch kit and a pump to be at least semi trail ready. As Jerry mentioned, some tape, wire, spare master link, etc is never a bad thing to have on hand for bodge repairs to get you home. In the end it really depends on where and how you ride. If you just commute around town or truck/trailer your Hawk to trails, you can get away with carrying less if you know you have other options nearby. If you plan on taking some big adventure on longer trails, and/or ride the bike to your destination and then go on said big adventure, then it is a good idea to go full Boy Scouts to ensure you can make it home.
#6 | |
![]() I'm Full Boy Scouts. I probably could rebuild the engine on the side of the road. ![]()
