11-07-2018, 06:29 PM | #1 |
Can you take piston cylinder off without messing with cam timing?
I got parts from RPS to repair my dinged up piston and messed up valves and head, and am wondering if I can pull the piston cylinder without having to reset the cam etc..
I tried searching here and google for it being documented for either the Hawk or original CG 125 and came up with nothing.. I don't want to offset the cam, crank, and magneto and see that the cam adjuster is on the piston-head, but it looks like it's just in the cavity under the push-rod holes. Thanks |
11-07-2018, 07:51 PM | #2 |
No. It usually turns just a bit while feeding the chain around the sprockets.
11-07-2018, 07:57 PM | #3 |
The CG250 is a push ROD engine so yes you can remove the cylinder without messing up the timing. No timing chain on the CG250.
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 11-08-2018 at 07:27 AM. |
11-07-2018, 08:50 PM | #4 |
CG yeah cause cam inside bottom cases
Maybe add in roller rockers while you are there Messing with cam timing can’t be an issue cause such a simple motor n line up the dots I assume |
11-09-2018, 08:34 AM | #5 | |
Forgot that that engine is a pushy rod type. |
11-09-2018, 08:45 AM | #6 |
Perfect opportunity to throw in some roller rockers. https://www.aliexpress.com/item/Bran...9-7f354bbbe4f6
11-09-2018, 12:59 PM | #7 |
roller rocker
WOW I am seriously tempted to try those !
It's snowing here now so im running out of dust to knock off the Hawk.
11-09-2018, 01:16 PM | #8 |
Even though any performance gain will be very small if any at all. Less friction does equal more power. It's one of the mods that I would do only if I was already pulling the cylinder off. I wouldn't pull the cylinder just to install them.
11-10-2018, 09:43 PM | #9 | |
Is there a difference? careful with Chinese details huh - around half the time I get stuff they are wrong and I am left fixing the issue. |
11-11-2018, 10:17 AM | #10 |
Most of these bikes aren't 250cc. They are between 200 and 230cc depending on engine model. Cam profile and max RPMs are the contributing factors to roller rockers having problems.
11-09-2018, 02:15 PM | #11 |
I would be more interested in those rockers if they offered an increased ratio. For the dollar I think that would be the best "bang for the buck" if it could be done.
11-09-2018, 04:35 PM | #12 |
if the cam lobe ramp angle is not steep enough to
require the use of a roller to climb it.. there is NO gain from a roller.. ( if the cam lobe angle is steep enough it will try and push a lifter side ways... then you need a roller) but they are cheap..So why not put them in .. i would just for the hell of it and because I can... .
11-10-2018, 02:03 PM | #13 |
I'm shy about using rollers, because the needle rollers are another point of failure. I've seen roller rockers grenade inside V8 engines, and those needles go places you don't want them. As Dan says, I'd be more interested in a different ratio.
11-10-2018, 02:08 PM | #14 |
Can someone tell me why my rockers wouldn't be moving? Got the piston and new head installed(great compression etc...), and rotated engine with pushrods set in the rocker joints and they don't move.. Exhaust is really high up and intake really low, and cam is moving etc..
I have the rocker pin set with the bolt tightened I'm hoping I can fix this there instead of pulling up the piston sleeve. Even though doing work on the piston sleeve is surprisingly fast and requires no special tools. |
11-10-2018, 04:31 PM | #15 |
are the push rods the same length ?
