10-13-2018, 08:50 PM | #1 |
Fires up, won't stay running.
Hello all,
I just built my Hawk last night. I took today to change fluids (fresh oil, fork oil, brake fluid) and heat wrap the exhaust and finally to change the front and rear sprockets. I went to fire it up for the first time and it fired right up!! Then it cut off. I can start it with the choke on all three settings, but it won't stay running...it just cuts off after 5 or 10 seconds. I have adjusted the idle screw counterclockwise a few times, but same results... What is my next step? |
10-13-2018, 09:04 PM | #2 |
How much gas in the tank?
Is the petcock tail end up ? Fuel line kink free? I know these are basically dumb questions but it's the small details.
10-13-2018, 09:11 PM | #3 |
1/2 tank of gas...petcock is on...fuel line has no kinks, it's a smooth "s-curve" from the petcock to the carb.
10-13-2018, 09:19 PM | #4 |
There's a fuel drain screw at the very very bottom of the carb crack it about 2 turns and catch the fuel draining out, it should have good uninterrupted flow.
Not spurts. Flow, spert.
10-13-2018, 09:30 PM | #5 |
Yep, turned that too. I let the fuel drain so that I could remove the carb. I was going to replace it, but decided to run stock for a while before I make changes. Fuel drained nice and smooth until it dribbled to a stop. Tightened the screw and reconnected the carb to get to the point described in my OP.
10-13-2018, 09:37 PM | #6 |
I'd pull the plug and see if it's wet or dry?
If it's wet it's fouled out. But it's a long shot.
10-14-2018, 03:09 PM | #7 | |
10-14-2018, 09:46 AM | #8 |
Did that fix your problem? When it is cold I have to turn mine a couple turns higher to get it going then back it off after a couple of minutes.
10-14-2018, 08:17 PM | #9 |
Fixed...thanks guys. The fuel tank was still half empty, but once I turned the idle adjust clockwise, it stayed running at a high RPM. I let it run for about 5 minutes, then I shut it off and adjusted the idle back down slightly. I was then able to start it with no choke and it ran beautifully. I took it for a ride and came home, filled the fuel tank and took it for 3 more laps around my neighborhood with zero issues!
10-14-2018, 08:40 PM | #10 |
Great to know, thank you for this information.
10-15-2018, 11:29 PM | #11 | |
10-13-2018, 09:55 PM | #13 |
OOOHHHHHHH!!!! Clockwise!!!! I've been turning it counterclockwise!!!
10-13-2018, 09:56 PM | #14 |
That might be it
